November 3
[57_1.png] rmackay9:
I know it is a lot to ask but it would be best if we could get the OSDs to use the [GLOBAL_POSITION_INT ]message instead
Is GLOBAL_POSITION_INT independent from GPS in case of unsufficient GPS reception ?
Should be. It’s the path’s canonical concept of its position.
I made this breaking change - sorry.
We created a google group to try to coordinate GCS-affecting changes
(where “GCS” means something that consumes our mavlink output in this
case).
https://groups.google.com/forum/#!forum/ardupilot-gcs
We did do a survey to see who was using what. That survey turns out not
to have covered anything near the things it should have.
I have a feeling I might be adding a parameter in to get the old behaviour
back. That makes me sad - that’s code which we have to (apparently) carry
indefinitely, taking up flash, developer time to maintain, a (small)
amount of CPU, introduces yet another parameter for our users to wade
through and reintroduces differences between our vehicles that simply
should not be there.
Peter
Visit Topic or reply to this email to respond.
In Reply To
[57_1.png]
rmackay9
November 2 Thanks for the report and sorry for not mentioning this in the release blog post (although there were so many things to list)… the issue we
faced is that the previous copter behaviour was inconsistent with the mavlink spec and also inconsistent across the ArduPilot vehicles (i.e. Plane and
Rover do …
You are receiving this because you enabled mailing list mode.
To unsubscribe from these emails, click here.
Peter Barker | Programmer,Sysadmin,Geek.
pbarker@barker.dropbear.id.au | You need a bigger hammer.
:: It’s a hack! Expect underscores! - Nigel Williams
