Dev Call Nov 5, 2018 2300 UTC
Issues & Pull Requests
Swarming
Plane
  • plane 3.9.3beta1,
  • Bug in RC channel count check
Copter
  • Copter-3.6 issues including VFR_HUD change to report ASL instead of Relative Alt
Hardware
Mateksys has offered to send a developer or two an F765 based flight controller. Any volunteers to do the port?
Attendee count (max): 20
Pre-agenda:
  • New version of ChibiOS has been in master for a while
    • Should consider moving to it on stable?
UTC2300 - battery parameter conversion broken on 3.6
  • https://github.com/ArduPilot/ardupilot/pull/9700
  • Removes some older parameter conversion code
    • Only people upgrading from something built in 2013 will be affected
  • For those that have installed current Plane stable
    • If they’ve fixed it in Plane then the fix will stick
  • Could be bad in Copter as it does have defaults for the battery failsafe stuff
  • This is an important fix for Copter and Plane
  • Randy will test this
UTC2305 - https://github.com/ArduPilot/ardupilot/pull/9690
  • Sometimes doing the sqrt and checking for NAN is actually a fast way of doing things
  • Need to make sure we’re not doing isnan checks afterwards
  • MdB quickly found a problem where blindly changing to safe_sqrt was the wrong fix
    • He will provide a patch
    • Not a good place to use safe_sqrt
  • Base it on floating point exceptions enabled in SITL?
  • We already die in SITL unless no-fpe is set, and you might want to replicate what will happen on stm32 - and this PR would stop that happening
  • Minimal fix
  • Doing this on the IO thread would be better
  • Merged!
UTC2310 - https://github.com/ArduPilot/ardupilot/pull/9661
  • ChibiOS IO processor firmware
  • As part of the continuing efforts to get rid of the PX4/NuttX submodules
  • Adds IO failsafe
  • Adds DSM support
  • DSM binding
  • Marge set of patches
  • Please test this!
  • Fixes a race condition
    • Intermittent Safety switch on boot issue
    • Fixes BRD_SAFETYENABLE intermittency
  • Hopefully 3 weeks to remove NuttX/PX4 Firmware submodules
  • Appeal for testing will go out
  • MdB will test after the call
    • Manual mask and safety mask
UTC2319 - https://github.com/ArduPilot/ardupilot/pull/9391
  • No update, tridge has been busy!
  • Along with lots of other devcall-marked issues
  • And one for Leonard
UTC2320 - https://github.com/ArduPilot/ardupilot/pull/8839
  • Needs to zero the structure
  • Check the return value of set_home and don’t lock a bad position in!
UTC2334 - changed the VFR_HUD message
  • Altitude in MinimOSD relative to Sea level ?!
  • Should we switch back?
  • Should we add a parameter so people can change it?
  • Minimosd
    • Only a couple of versions we care about
  • HOTT and graupner
  • JP: we need to get it right at our end
  • Use devop bit to get back old behaviour
  • For people that can’t update their minimosd firmware
  • https://github.com/mavlink/qgroundcontrol/pull/6986
  • Would like to use minimosd as a screen update protocol rather than mavlink
    • Use existing ArduPilot OSD code
    • Would also future-proof things
  • Mavlink screen-painting message?
  • Peter will add a devop bit to get back old behaviour
    • Add comment on discuss post
  • Need to work on getting testers before we issue stable
  • Working with consumers of our telemetry stream
  • Users don’t update?
UTC2350 - akshath and swarming
UTC0002 - Plane updates
  • 3.9.3beta1 is out this-morning
  • Minimum necessary changes from 3.9.2
  • Tridge found a situation where corrupt RC input would induce a crash
    • Unlikely to happen in practise
    • Range-checking issue
  • Fix speed-scaling on very fast aircraft
    • Old limit between 0.5 and 2
    • Very fast jet 250km/h needed scaling all the way up
  • 3 new boards added
  • Gpio numbers are now consistent across all boards
  • 50-55 for first 6 aux channels
  • Kakute fixes
  • Should be a quick beta
  • RC options bit to disable s.bus failsafe is not in master yet
    • Lots of OBC stuff to pull in
UTC0007 - Copter update with Randy
  • 3.6 went out a week ago
  • Bunch of things have come up
    • https://github.com/ArduPilot/ardupilot/issues/9498
    • A number have already been fixed in last 48 hours or so
    • Downgrading has been fixed
    • D-shot dma thing is in progress
    • No sd cards can’t do terrain following
      • Should be able to use laser
      • Need to fix missions
    • In SITL vehicle will skip spline waypoint
      • On Leonard’s plate
    • Performance issue on uavcan is with Francisco
    • Compass switching on EKF3 is happening a lot
      • With Paul
  • 3.6.1 will be getting more hardware definitions
  • 3.6.1 beta will start today
UTC0010 - Rover update with Randy
  • Beta soonish
  • Sailboats are in master
  • Iampete has done documentation!
  • Since we put in external position estimate support there’s a constant stream of people using it
UTC0016 - partner’s call tomorrow morning
UTC0016 - Canberra dev meetup!
  • deposit for conference are being paid
  • 23rd and 24th of March
    • Solid dates
    • Book your plane tickets now!
  • Turn up ahead of time for MORE fun!
  • Separate smaller meeting room with projector earlier days than the conference
  • Applications to funding committee early would be a good idea
    • It’s a devteam conference
      • But special cases might be looked at
    • JP: It will only be funding for a very small number. Preference is for sponsored (employer?) attendance where possible
  • Book your rooms!
    • Proper announcement as to where will be made on the Discourse server
    • Including a discount code
    • Rooms will be a little cheaper than last time
  • Advertising starts now
  • We’d love to see lots of our newer developers come along
  • Will be using lake to show boats off
  • Arduplane off floats would be nice
    • Would have to go to Belconnen to do this
  • Olivier is going to try to make it
UTC0023 - vector graphic logo
  • Any reason not to create and add to repo?
  • In the ardupilot_wiki on the trademark page
UTC0024 - trademark is moving along
  • Sflc is chasing it for us
