Hi, guys
This time, the MFE team brought you our new aerial test drone, the Hero VTOL. Here are some detailed information about the Hero.
Hero VTOL Fixed wing Aircraft
The Hero VTOL is a multi-purpose vertical take-off and landing fixed wing. The unique design of the UAV nose can be replaced, which can be equipped with an orthophoto camera or a tilt camera when used in the field of surveying and mapping, and can be equipped with an optoelectronic pod in the field of monitoring. The multi-purpose design expands the range of applications and reduces the cost of flight.
Basic Parameters
Wingspan: 2180mm
Vertical arm: 755mm (including motor base)
Wing area: 53dm²
Body height: 255mm (including tripod)
Cruising speed: 17-22m/s
Body length: 1140mm
Aircraft angle of attack: 0-2°
Wing Mounting Angle: 2.9°
Stall airspeed: 12m/s
Conversion airspeed: 14m/s
Maximum climb angle: 3.5°
Maximum dive angle: 5°
Maximum roll angle: 30°
Payload: <1kg
Take-off weight: <7kg
Take-off altitude: <3000m
Ceiling altitude: 6500m
Wind resistance: level 5 (normal operation)
V tail angle: 28° up, 20° down
Disassembly method: quick disassembly without tools
Working temperature: -10℃-50℃
Packing box size: 1100x350x430mm
Aileron Rotation: Up 22° Down 28°
Take-off and landing method: vertical take-off and landing
Material: EPO, carbon fiber, aviation aluminum alloy, engineering plastic, etc.
Mapping endurance: 136min/144km (speed 19m/s, load 600g,Battery 6S@22000mah, take-off weight 6.65kg)
Monitoring endurance: 125min/126km (speed 18m/s, load 450g,Battery 6S@22000mah, take-off weight 6.5kg)
Efficient Aerodynamics
The Hero VTOL adopts a streamlined shape as a whole to reduce flight resistance as much as possible while ensuring stable flight.
Official Website: https://www.makeflyeasy.com
Technical Support: https://doc.makeflyeasy.com
Download: GitHub - makeflyeasy/MFE_ArduPlane
Contact Email: makeflyeasy@qq.com
Facebook: Redirecting...
Official Purchase:https://www.aliexpress.us/item/3256804611396135.html?spm=a2g0o.store_pc_groupList.8148356.1.79f52d91PzkcYp&pdp_npi=2%40dis!USD!US%20%24692.00!US%20%24692.00!!!!!%402132a21116667518425002244e7058!12000030523953147!sh&gatewayAdapt=glo2usa&_randl_shipto=US
