Lo normal es que así sea; los alerones van a la misma salida. Eventualmente pueden ir a canales indepedientes si se quere tener un control muy fino del alabelo.
Hi udamudam
I have fighter VTOL 4+1 Quadplane , and i have faced many issues about wiring diagram CUAV v5+ and parameters…
Please can you send me your wiring setup and parameters…
My regards
Ala
Still flying the Striver…
Changed radios and put a camera out near the wingtip to get a clear forward view.
Did a flight test today and forgot to turn the cameras on
Otherwise, stills fly solid. Maybe tomorrow get a camera check…
Remembered to turn the wingcam on today!
Looks like it bounces a bit so next flight I’ll turn on the stabilization and see if it helps the video.
Uploaded a short video that shows the prop visible in quad mode. But after transition, it streamlined and stays out of the camera’s view (about 32 sec in you can see it disappear on the left side. Also left a minute of the landing transition to see it reappear into view.
took another flight w/the camera stabilization on … think it will be fine for watching the flight progression…
[Edit so I can post more than 3x]
Tried to get a quick flight in this AM before the rain … didn’t make it …
Hit RTL. During the rough descent, you can see little streaks as if the camera was failing. Those are the rain drops that just became a downpour at touchdown.
