[SOLVED] MAVROS yaw folding past 180°
I had two crashes during GPS-denied indoor flights and I think I found the cause, but I am not a MAVROS expert so I would love to hear if anyone else has seen this.
We are running a ZED 2i into ArduPilot EKF3 via MAVROS on ROS Humble / Ubuntu 22.04, publishing vision pose to /mavros/vision_pose/pose. Two things kept happening:
First symptom: every time the drone rotated past roughly 180°, the yaw reported to ArduPilot would fold back instead of continuing. A full 360° spin produced 0 → π → 0 → π instead of the correct 0 → π → −π → 0. So as the drone kept rotating, EKF3 was seeing the heading suddenly reverse direction — and would try to correct for it.
Second symptom: sometimes the drone would start up with a yaw of ~3.14 rad. Since that is so close to 0 in the EKF’s view of the world, it would arm fine — but then fly toward the operator when commanded to go the other way, because its sense of north was flipped.
After a lot of head-scratching I traced it to this function inside MAVROS (mavros/src/lib/ftf_quaternion_utils.cpp):
Eigen::Vector3d quaternion_to_rpy(const Eigen::Quaterniond & q)
  // YPR - ZYX
  return q.toRotationMatrix().eulerAngles(2, 1, 0).reverse();
From what I can tell, Eigen::eulerAngles(2,1,0) always returns the primary axis (yaw, in ZYX) in [0, π]. Any heading past 180° gets folded back into that range rather than going negative. I replaced it with an explicit atan2 decomposition:
  auto m = q.toRotationMatrix();
  return Eigen::Vector3d(
    std::atan2(m(2, 1), m(2, 2)),   // roll
    std::asin(-m(2, 0)),             // pitch
    std::atan2(m(1, 0), m(0, 0))    // yaw — now covers (−π, π]
After that change the yaw folding stopped and we have not had another crash from this.
Looking through the MAVROS issue tracker I found this has apparently been reported before — #358 (2015), #444 (2015), and #1472 (2020) all describe the same [0, π] yaw range problem — but as far as I can tell no fix was ever merged, and the ROS2 port in 2021 carried it forward. I also read that publishing to /mavros/mocap/pose instead might avoid this entirely since that plugin sends a quaternion directly, though I have not tested it myself.
I opened a PR with the fix: mavlink/mavros#2232.
Has anyone else had this problem or found a different explanation? Would also be curious if this only affects ROS Humble or if earlier versions have it too.
Okay everyone, just a quick update.
This was a known problem, I consulted with @snktshrma who said this used to happen back when he used mavros for his projects. He also talked about the mocap frame fix btw.
The PR got merged into ros2 branch - so the problem is solved. I tried it in flight and it looks great!!
