Some more information is helpful
- Your A2 mini firmware version
- Your MK15 firmware version
- Your SIYI TX and SIYI FPV app version
- What switch did you assign for A2 mini control? Have you also tried the dial?
A2 mini gimbal firmware: V0.1.5
A2 mini camera firmware: V0.1.9
MK15 RCU Ver: 5.3.7
MK15 SkyEnd Ver: 5.2.4
RCU Image Transmission Ver: 0.2.2
SkyEnd Image Transmission Ver: 0.2.2
SIYI TX firmware: V1.1.210
SIYI FPV firmware: 2.5.12.527.2884636.20230208
I tried either switched SB or SC and dial RD with both “Auto Back” or “Non Auto” and it did not work. Dial is calibrated.
BTW, we did buy 2 cameras so I tried to swap them and the second camera has an identical behaviour.
By plugging the A2 mini camera to MK15 air unit, we can control it by both the touchscreen and by PWM (like how we control the LED in the IP67 camera). The 15 and 16 channels were fixed for the LEDs in IP67 Camera A and B type. After the release of A2 mini, the channel 15 can be used for gimbal pitch control now. You need to switch it in the latest SIYI TX app.
Your A2 mini firmware is the latest.
Please sync the latest MK15 firmware after updating to the latest SIYI TX app. Then you can try to switch the control of channel 15 to gimbal.
Thank you Frank!
I have updated the SIYI TX app to V1.1.232.1e79fe9 and unfortunately I cannot update the firmware.
I have installed the drivers and I can see 2 installed devices in Device Manager but when I check the Siyi Assistant windows app, there is nothing there.
What should I do?
Thank you!
Please send an email to support@siyi.biz
The email support will take over your issue.
Hi! The email provided does not work. So I am attaching all new info here.
I have managed to upgrade the Siyi TX app to V1.1.232.1e79fe9.
I have not managed to upgrade the Siyi AirUnit firmware or the RC unit firmware. I have precisely followed the instructions provided for the drivers for the RC unit and I can see the RC unit in device manager as shown in the attached image, but the Siyi Assistant (v1.3.2) does not see anything, therefore I cannot upgrade anything.
I have not managed to upgrade the Siyi AirUnit because, although the Siyi Assistant saw it, and I chose the right version of firmware, the upgrade stops each time at 31%, as shown in the second attached image.
How should we solve this?
We are completely disappointed in the product. We have spent 2 days to solve one simple thing. Point the camera forward. This is far from acceptable.
Please disconnect all other cables on the air unit and keep the power cable and the upgrade cable only
Thank you, that worked. What can I do about the RC unit?
Please repeat the steps but using the upgrade cable for the RC
I have just tried again on a different machine (laptop) and I get the same result though, on this one I am unable to install the drivers.
This is what I did, in that order:
I am doing something wrong?
Your PC Assistant is already reading the air unit port for firmware update, which means you don’t have to bother with the drivers.
Have you sucessfully flashed firmware for the air unit?
Yes I have successfully flashed the Air Unit. And I do not yet manage to have a connection between the RC unit and Siyi Assistant.
Hi Frank! So I managed to upgrade but I still cannot select gimbal in the TX App - System - Channel 15, as you suggest here Notice - A $2?9 Mini Android Controller from SIYI - 10 KM Range @ 1080P 180 ms, 8-core CPU - #856 by SIYI
My current firmware are:
MK15 RCU Ver: 5.3.8
MK15 SkyEnd Ver: 5.2.8
SIYI TX firmware: V1.1.232.1e79fe9
What should I do? I still cannot point the A2 mini camera forward.
I have updated the SIYI TX app to SIYI_TX_1.1.235.e934a06.20230225 but I still cannot select the Gimbal button. Its there, I click it but it does not get selected.
Is that a problem for air unit of MK15 if there are 2 different antennas mounted ?
The problem could be that the 5.3.8 RC firmware does not match the latest SIYI TX app. Please try to update RC to the below version.
I managed to select Gimbal in Channel 15, under Settings, in the SIYI TX app, with the above RC software but the camera is still pointing upwards. It is pointing upwards even if I modify the channel 15 limits.
What is the next step?
Please try to use one of the dial to control channel 15
Finally that works. Thank you. The camera stops at 1500, moves down at lower and up at higher pwm values.
