thank you for the replay!
those are my first steps with RPI … sorry…
nmcli d wifi list -> show only the ardupilot SSID. i do not get any other!
two qus
1.how can i connect to other SSID (what is the cmd list ) ?
2. what happen the next time i’ll reboot the RPI ? will it connect to this new WIFI SSID ?
I can connect my raspberrypi3+ and apsync with QGroundcontrol. Video Streaming is fine working. The Copter is good flying with controller Pixhawk2.4.8.
When I type:
root@apsync:/home/pi# mavproxy.py --master=/dev/serial0 --baudrate 921600 --aircraft MyCopter
Connect /dev/serial0 source_system=255
no script MyCopter/mavinit.scr
Log Directory: MyCopter/logs/2020-09-26/flight5
Telemetry log: MyCopter/logs/2020-09-26/flight5/flight.tlog
MAV> Waiting for heartbeat from /dev/serial0
On my oscilloscope I can see that TX from the Raspi sends a command to RX from the Pixhawk2.4.8, but the Pixhawk does not answer. Where is the mistake?
What must be in MyCopter/mavinit.scr? Is this the problem?
Hi, every thing was working great for few days…
now i have a problem with GPIO14 (tx of the RPI).
i get same problem with 3 Flight Controler that where fine.
i get data bat not read the parameters of the FC (parm list) so can not send command!
is there a way the set other connection as TX (other GPIOxx )?
Thank You
Ram
Hi Stephen, great work with this image! Is there a somewhat easy way to disable the access point and feed all the data through the ethernet port instead? I don’t have extensive networking knowledge so don’t know if it is possible or not.
