First of all thank you for your response. After arming i increased throttle, when throttle reach 15% motor will started to spin…
When i hold throttle at 15~20% it top two motor & bottom left motor increasing it speed, but bottom right motor is still on 15% throttle speed when i increade throttle it’s speed also increase but comparatively slower than other motors.
Hope you understand.
Thanks
If you’re testing this on the bench then don’t get too worried about the motor speeds. When the drone is on the bench, the control loops are getting confused and it shows up as unusual motor RPM.
Use the motor test function in Mission Planner and make sure that everything there is working as it should.
Did you see the first video… Both motor have different speed… In second video it automatically turn to left without tx input… Did you notified that?.
So if i take it outside it will crash.
Now i tried to replace the signal wire from esc to cube… The 4th motor is slowest one… ( 4th motor based on motor layout or bottom right motor)
I changed first motor signal pin to 4th main out of pixhawk & 4th motor signal pin to 1st main out of pixhawk.
When i tried this… The 4th motor started to work fine… But 1st motor become slower…
So problem caused by cube??
Thanks advance…
The different speeds are normal and to be expected.
Take it outside and it will not crash.
We have explained this many times to many different users in this forum. You are not the only person that does not understand what an open control loop is. None of the users had a crash when they took the Copter outside.
Read this forum, to confirm it if you do not believe us
I’ll echo what the others have said. Make sure you have completed the motor tests with MOT_SPIN_MIN and MOT_SPIN_ARM set correctly. Make sure all the motors are spinning the correct direction for their position. That’s all you can really test on the ground. The speeds will be different and errors will multiply because the drone can’t move (or move fully) to allow the control loop to do it’s thing.
My friend also faced same problem, In stablize mode all motors are working fine.He tried in Loiter mode and drone got crashed. Problem was the same 2 motors were not working properly. Response was the late
I can’t be the same problem if you are describing a crash. This post is about the common mistake of running the motors on the bench with the Transmitter and believing something can be learned. That craft never left the ground in this post.
I am also facing the similar issue with the Hexsoon EDU450 frame ,iam using cube orange plus ,when i arm the copter the motor 1 starts spinning and rest of the motors are not , and when i give throttle to 15% the motors starts to spin but one motors spins faster , i have faced the same issue with the pixhawk 2.4.8 ,at that time i have changed firmware and did esc calibration everything seems fine ,but the same thing is not working with cube orange plus ,hope everyone understood.
Thankyou
