Greetings,
I would like to design/create a test bench and experiment with different mot_thst_expo values. Does the “motor testing” feature of the mission planner uses this parameter or it just sends PWM according to the percentage value that I setup? If not, should I use a STABILIZE flight mode in order to test my motors? Since I can test only one motor (huge propellers) is this a valid way of doing it?
Thanks
