@blenderlab I cannot see the 2.3 firmware for X9 to download, am I doing something wrong?
Well, here comes my github account where I just uploaded the firmwares I have :
https://github.com/blenderlab/JJRC-X9
I read/flashed them with STlink (under linux).
For testing :
- my X9 2.3 works well (boots up etc) but I donāt see the droneās Wifi (might be a connection issue, have to check everything)
feel free to ask questions !
@blenderlab do you have test reset drone with fw for version board 2.3. "do you have check version fw?if not have wifi hard impossible check the version in the app.
pls insert battery and press 4 time fast the button battery. the drone check the reset with one minute blinking blue led.to finish blink led blue. unplug battery and reboot x9.
test if have WiFi lan access point.
check this ā¦ best regards
thanks @Cento for the tip (wher did you find that !?)
I still donāt have wifi AP, so Iām opening the X9 to check wiringā¦
stay tuned !
ā after dismanteling X9 : ā
Still no Wifi, averything seems ok, and the Atheros chipset is soldered to the powerboardā¦ It might be a minor upgrade in the HW or FWā¦ (shit happens)
This is normal pleasure for reset drone please open manual.
Eject batteryā¦
Insert battery and press 4 time fast the button batteryā¦
And led blue need blinking for 1minutes max 1.30minutes .
If not work you have low speed for click button 4 time.
Very fastā¦
Like number 3
This pleasure working ā¦for reset drone
hello have detail for board ? I have board 2.1 and 2.3 and have same connector optoflow and hare connected to micro camera sensor.
do you have tested login by telnet to ip drone?
@Cento Hello, the X9P V2.3 has an optoflow connector, but not used anymore. The flow goes through the camera wires (I Think).
I should Read the manual entirely ;-D Iām going to try the slow reset too.
Are these updates or original firmwares that came with corresponding boards? I have a v2. 2 board so I cannot use version 2.3 or any higher version?
picture please for check detail
thanks
my 2.3 X9 is same this board.
Does it mean that I can load v2. 3 on my v2. 2 board without any problems?
if you know how to make a proper backup you can also restore it. to use windows or linux? pay attention to all the data to be read. start and end address
Hello, my name is Mirco from Italy and Iām new.
I have a JJRC X9 V2.2. I replaced the original GPS module with a TOPGNSS receiver equipped with M8030-KT chip with FLASH, and configured it to receive GPS + GLONASS + GALILEO. So I saved the settings on the receiver flash. With BaudRate = 9600 (default) it works well, but increasing to 115200 the JJRC X9 drone causes the GPS Reset to the default version and connects to 9600 anyway. I would like to ask if there is an easy way to set the droneās UART GPS port to 115200 instead of 9600. Thanks.
I found these factory configuration parameters, but I donāt know what the GPS serial port is ā¦
Maybe it happens as in the DJI Phantom3? the connection is established with the default baud rate, then a command is sent to increase it?
I tried loading one of these onto my board but the board said the file was too large. It indicated that it takes about 487kb or so.
Can some one backup original parameters of the c-fly dream or jjrc on flight planner and post them here. I was playing around with mine an they are totally off. I didnāt backup beforehand. Thank you
hi can you teach me how to set jjrc x9 using topgnss
Youāll find all the firmwares I have collected on the internet here : https://github.com/blenderlab/JJRC-X9
As know, firmware versions ARE NOT upgrades. The fit to hardware revisions, so, unless you have backup, donāt try to flash upgrades version.
have a nice flight,
Thomas
