OK
Here are the curves from Sept 19 fly (corresponding to the pictures and video showned on this date in this thread):
Zooming deeper , we can see noise - I consider normal - but no glitches as you have
OK
Hi @anbello, thank you for testing out the system!
Besides what @ppoirier has suggested, you can also check out the confidence level in each of your test, just to make sure the T265 worked well in the non-ROS tests and the issue was the script.
@LuckyBird and @ppoirier follows another test in circle and console out from the script (during circle confidence always HIGH):
ubuntu@anbelloros:~/catkin_ws/src/vision_to_mavros/scripts$ ./t265_to_mavlink.py
INFO: Using default connection_string /dev/ttyAMA0
INFO: Using default connection_baudrate 921600
INFO: Using default vision_msg_hz 14
INFO: Using default confidence_msg_hz 1
INFO: Using camera position offset: Enabled, x y z is 0.11 -0.01 0.08
INFO: Using compass: Disabled
INFO: Using default scale factor 1.0
INFO: Using default camera orientation 0
INFO: Connecting to Realsense camera.
INFO: Realsense connected.
INFO: Connecting to vehicle.
INFO: Vehicle connected.
INFO: Sending VISION_POSITION_ESTIMATE messages to FCU.
INFO: Tracking confidence: Medium
INFO: Tracking confidence: High
WARNING:autopilot:Radio Failsafe - Disarming
CRITICAL:autopilot:PreArm: Radio failsafe on
^CINFO: KeyboardInterrupt has been caught. Cleaning up...
INFO: Realsense pipeline and vehicle object closed.
That looks so much like a communication problem … it is puzzling that MavRos is ok
Can you try reducing BaudRate to 115200 ?
Just tested with baudrate 115200, same problem
From the log of my latest flight, the script seems to work fine.
@anbello :
vision_msg_hz
in t265_to_mavlink.py
script and param output_rate
in t265_tf_to_mavros.launch
file)?LOG_DISARMED
enabled and see if there are any drops like in real flight?I used same rate for non-ROS and ROS, tested 30, 14, 10 Hz and I always have problem only on non-ROS.
I will try handheld test for non-ROS with LOG_DISARMED later and let you know.
@LuckyBird follows the plot from handheld test for non-ROS, it seems worse when there is more yaw, anyway the confidence was always High.
Hi @ppoirier
Referring to post 74 and 76: I tested the VIO non-ROS script today. As per your suggestions I decreased the vision_msg_hz to 20hz. I took off in altitude hold and switched to loiter and it worked beautifully. When I took off in the loiter mode, the drone wasn’t as stable as before and started drifting away. I was also getting DCM Roll/Pitch inconsistent by 85 deg and EKF2 Roll/Pitch inconsistent by 21 deg error. Could this be an camera orientation issue? Note: The camera is downfacing with around 30 deg tilt for better yaw estimation.
Thanks
Yes that is a strong probability as the transform matrix is expecting orthogonal coordinates, you could look at the logs and compare visual RPY with IMU
Hi @anbello, enabling the debug option can help us inspect the raw data and transformed data within the script:
./t265_to_mavlink.py --debug_enable
../t265_to_mavlink.py --debug_enable | tee non_ROS_log.txt
Hi @anbello, the plots of the recorded data look ok.
You can compare them to the VISP plot of flight log. It seems to me the most plausible explanation is the communication.
Thanks for the anlysys @LuckyBird from the following graph is evident that, as you said, is a problem of communication. Top half of the graph: output from your script, bottom half: data from log. This is one of the test with less errors that I saw, normally there are more (as you can see form my other posts).
But I don’t understand why I don’t have this problem with ROS, in the two situation I have the same communication channel: serial from RPi3 to Pixracer. The only difference I can think is that with mavros the serial com is implemented in C++ while with your script in python.
Looking at it , it seems that the glitches are happening the circle phase.
@anbello could you try with your externally generated python circle script ?
Here are some suggestions that I can think of for the software side of things:
Basically we can throw all of the variables that make the two implementations differ from one another against the wall and see which one sticks :))
There should be some strange interaction between main task and scheduled jobs, with this modified version that doesn’t use scheduler lib I have no error and also less CPU load from 80% to 60% (for all 4 cores).
For now I only tested handheld, I will do a real test flight ASAP.
Follows plot:
@anbello Glad to know you got it working. On my setup with RPi3 the CPU load never got more than 40% so the issue did not occur. I suspect some messages got dropped by the scheduler whenever the CPU load is high.
If you are still interested in debugging the original script, I made a new version with debug message of elapsed time between consecutive messages and when a message is missed here in this branch.
Thanks @LuckyBird I will test your script with debug message but I would like to know why so big difference in CPU load, we are using same SBC (RPi3), which OS do you use?
A thought about what happen in the script:
I am not an expert in multi threading programming but I fear that there could be some problems in using H_aeroRef_aeroBody as global variable that is written in the scheduled job and then read in main task.
[Edit]
It is for this thought that I eliminate the scheduler to use an “old school” method using timer. Moreover in this way I have less CPU load, I am curious if this is true also for you, could you test the script without scheduler on your system and report CPU load?
