Auto takeoff worked well, FBWA seemed ok at first, then all hell broke loose. You’d think we would have been safe at the worlds biggest flying field!
flight controller is a cheap Pixhawk 1. about 100 flights without an issue like this, but of course, only about 10-20 flights on Arduplane 4.1.x.
I would really like to know if this is a bug in EKF3 affinity switching, or a consequence of using a cheap flight controller. Would a Cube Orange have done the same?
The lane selection logic got suckered into a switch to the second IMU EKF by a GPS glitch at 04:54:50. Unfortunately IMU2 had developed a large Y gyro offset before takeoff and was in intermittent bad health which allowed the switch.
This is another example where the user should have been warned by the GCS if the backup EKF is unhealthy.
Plotting the data for the two Y axis gyros shows the fault clearly:
Thanks for looking into this! Looks like a Gyro bias jump, but the sensor reading looks healthy for me besides this jump at 4:54:18. Are there any plans to add some preflight checks to Mission Planner maybe to find similar errors?
Hello all. I have a question about EKF3 estimations.
Can bad GPS data cause errors in the estimation of angular orientation?
When does EKF3 lane switching happen?
