Copter-4.0.1 has been released as the official firmware for multicopters and traditional helicopters!
The changes vs 4.0.0 are in the ReleaseNotes and copied below:
FrSky telemetry status text handling fix (Critical Fix)
Circle mode allows pilot control of radius and rotation speed
CAN servo feedback logged
Magnetic declination tables updated
Serial0 protocol forced to MAVLink (avoids accidental disabling of USB port)
Minor Enhancements:
a) Autorotate flight mode renamed to Heli_Autorotate
b) Solo default parameters updated
c) âPrepared log systemâ initialisation message removed
Bug Fixes:
a) TradHeli RSC RC passthrough fixed
b) CubeOrange and Durandal I2C timing fixed (was running slow)
c) Compass calibration auto orientation skips âpitch 7â which could cause cal to fail
d) Durandalâs fourth I2C port fixed
e) Linux boards with CAN support fixed
f) Neopixel added to SERVOx_FUNCTION param description
g) NMEA Output fixed (was sending an extra CR)
h) Optflow messages sent even if EKF has no height estimate
i) SkyViper build fixed
j) Spektrum/DSM 22ms RC input fixed
k) âUC Node Downâ message removed (was unnecessarily scary)
l) Semaphore fixes for Logging, Filesystem and UAVCAN Dyanmic Node Allocation
m) RangeFinder parameter fix (4th rangefinder was using 1st rangefinderâs params)
n) TradHeli STB_COL_x parameter description fixed
The most important change is â1) FrSky telemetry status text handling fix (Critical Fix)â which resolves the critical issue announced in this blog post.
WARNING: we have seen two reports of CAN compasses not being recognised at startup unless BRD_BOOT_DELAY is set to 5000. This parameter slows down the autopilotâs boot time (by 5 seconds) which gives more time for the CAN peripheral to startup. This is not a critical âbugâ that should lead to crashes but we would like to hear from users if they are having troubles with CAN compasses being detected.
Special thanks to our beta testers for testing this release over the past few weeks. You are a critical part of the process and we really appreciate your help! Thanks!
Thank you for your hard work randy and other developer who involved in this release.
By default this value is BRD_BOOT_DELAY is 0.
As you said randy dynamic Alt change and dynamic ground speed change in auto mode will work in AC 4.x release.
But I have tried many times itâs not working at all,When I go extended tuning parameter page and change wp_speed to what ever value then only it take effect.
In auto mode there is no stop and turn method even AZ degree goes above 90 degree from current heading but sometimes it does I donât couldnât find the reason. Whem does it will make stop and turn and bank turn (current method) it use roll as well about 13 to 15degree to achieve within this desired point. But it looks sometime very Stanger.
Please give me some feedback to over come this issue.
Good day, ive install today the version 4.0.1, ive a drotek r3100 wired on mro can bus on the i2c after the calibration the rm3100 its not recognize, setting the boot delay as you adviced but nothing happened.
I did not find the same issue on version 4.0.0.
i will attach the log25.01.2020.bin (283.5 KB)
Mav FTP, on pixhawk 2.4.8 is not working. In âdevâ firmware ftp is working(from https://firmware.ardupilot.org/Copter/latest/fmuv3/), but there are down some other fings, like radio control with telemetry, heh it canât fly in one word.
Copter doesnât support dynamically changing the altitude during missions. Thereâs already a request on the issues list covering this but I canât promise when we will get to it.
There was an issue with the build server which meant that Copter-4.0.1 didnât go out at the expected time. Itâs out now but from looking at the log youâve provided the vehicle is still on 4.0.0. Perhaps something else has changed in the setup to cause the rm3100 to not be recognised?
Iâve just checked MAVFTP using MP with a CubeBlack running Copter-4.0.1 and it appears to work. I press Ctrl-X and then I can open the APM/TERRAIN folder and see some .dat files in there.
I wonder if perhaps MAVFTP is not available on the fmuv2 builds and that this is what is being loaded onto your board if MPâs firmware install screen is used. The firmware that is being used is shown in the messages sent to the GCS soon after a connection is made. For example below is a screen shot showing that Iâve got the CubeBlack on my board. Can you confirm you have the fmuv3 firmware on your board when MAVFTP is not working?
Another possibility is an issue with MP (or whatever GCS youâre using) although this seems unlikely because youâve confirmed it does work with Copter-4.0.1-dev.
If you have a moment I was wondering if you could confirm that the rm3100 (present on a DroTek F9P Sirius GPS unit) is working for you with Copter-4.0.1? I think youâve confirmed it was working in Copter-4.0.0-rc4 so it should still be working but if you could double check that would be a great help, txs!
It was working in the latest 4.0.1 Dev build which was post rc3. I will be upgrading mine tonight to the stable 4.0.1 and I will confirm it works. The only difference and not sure it matters but my rm3100 is on the can bus
Good day, the setup didnât change⌠rm3100 is connected on i2c port of can nodri will flash again the firmware and i will check if the rm3100 will be recognized⌠i will let you know
I just tested 4.0.1 on both a Holybro Pixhawk 4 mini and a CUAV V5 Nano and the rm3100 compass got picked right up no problem⌠This is in the CUAV NEOV2 Pro CAN GPS with RM3100 Compass. I am not sure if I2C is different
I will try to get this loaded on my CUAV V5+ Cube tomorrow to see if the results are the same
I have seen parameter FRAME _TYPE to many configuration and also seen 13 DJIX.
This means motor order and connection also will differ?
Because DJIX configuration is start from right top motor 1 and counter clockwise its 2, 3 4 respectively.
But where as arducopter is different.
Looking at the AP_Motors library it seems like our âDJI Xâ frame is setup to order the number in counter-clockwise as shown here. In my (limited) experience with converting a DJI hexacopter to use AP, the motors were in clockwise order so I tend to agree with you. Do you have some reference that shows the DJI motor order is clockwise? This would help with the discussion to possibly have it changed.
Dji motors order are always start with front right motor and counting towards its counterclockwise direction. Itâs not clockwise direction.
One thing I have noticed in AC hexacopter when do YAW command from RC remote some motors are almost it reach stop condition (very low rpm and we can see it in our eyeâs also).
But in case of DJI motor order I didnât see such different why?
Thereâs any special reason for putting motor order in different way in AC.
