Copter-3.6.0-rc5 is ready for beta testing. The list of changes can be seen in the ReleaseNotes and also copied below.
Changes from 3.6.0-rc4
Support new boards CubeBlack and HolyBro Pixhawk4-mini
ChibiOS small enhancement and fixes:
a) make board serial number match NuttX
b) relay fix for Pixhawk boards by defaulting BRD_PWM_COUNT to 4 (same as NuttX)
c) MatekF405-Wing default compass orientation fix
d) Pixhawk4 default compass orientation fix
e) Omnibus F4 Pro I2C fix
Bug fixes:
a) Telemetry baud rate fix
b) RC failsafe fix to RTL in all modes except Auto when FS_THR_ENABLE is continue-with-mission
c) waypoint navigation related safety check that PSC_POS_XY_P is non-zero
d) aerofc-v1 update bootloader utility fix
There will certainly be an -rc6 to resolve some known issues including:
Any reason to expect different compass behavior with this release? MP reported “compass not calibrated” after updating from Rc4 (chibios both). And the 2nd on-board compass on the PixRacer is not recognized when doing the calibration. I think this can be seen in the device ID’s comparing them to the Rc3 release which is the last I have a saved parameter file from. They are identified differently.
Hi I like to install using load custom firmware can you give me the direct link to the directory for px4-v3 rc-5? I am lost. normally it in the latest directory? but the firmware does not say RC-5 after loading unless I use MP load beta. Where is MP pointing to?
That is a bit of a concern. There was a change related to the compasses. It was meant to be a non-functional change but perhaps something went wrong. Txs for the report. I think we should be able to reproduce with a pixracer but we may need a dataflash log file from you…
Brandon,
Txs for the report. re EKF errors during dataflash log downloads, I think that happens in Copter-3.5 as well. It’s potentially something we should fix but we may not fix it in Copter-3.6.
Hi happy to report that the Green frog is AOK using ChibiOS copter-mRoX21-beta-test.apj you made me! and is working really nice !! floats like a dream!! Big thank you and Randy as well!
IronMan 650 Sport
400kv
ESC XRotor Pro 50A
3.6.0-rc5 Pixhawk 4
stabilize mode.
When I started the takeoff all seemed stable, but at about 3 feet the quad took a nose dive and landed on its back. Ended up with only one broken antenna.
Actually I have a hunch that the cause is due to mechanical failure but I’m not sure. I am not proficient enough in reading the logs so any input would be appreciated.
