Cheerson CX-OF - Flowhold - Whobble
Today i tested the Cheerson CX-OF sensor in the field.
Loiter and Stabalize work flawless
There is a oscillation (whobble) while hovering in flowhold mode.
It disappears when flying low (<3 ft) or at higher speeds and is very noticable hovering at 5 - 20 ft altitude.
When taking a look at the logfiles, i can see an oscillation
Looking at the times where GPS.Speed is around 0
and then look at any Flow or accelerometer oscillations
How to finetune this oscillation. Is there a PID mechanism for flowhold?
Frame is 25" spinning 1155 props on 3S LIoN (hence the low voltages at high current)
For others having the same issue;
I Decreased
FHLD_XY_I to 0,2
and Decreased
FHLD_XY_P to 0,1
Try adjusting these params… Maybe it solves your issues to
have you looke at the original blog ?
Hello. Did you got some other better values for these parameters? I’m facing this problem too. Reducing the ?_FILT_HZ to 2 solved partially, because the displacements are higher, i.o.w., the drone position varies a bit more.
Regards!
