Hi everyone,
I’m using a Pixhawk with 4.0.5 and a Frsky R-XSR, OpenTX 2.3.10. I’m trying now for several hours, no luck. I’m using an inverter between S.Port and TX/RX. Tried Telemtry 1 and 2 ports, both are working with standard Mavlink modem. Disabled RTS/CTS, protocol set to FrSky Passthrough, SERIALx_OPTIONS is 4 (Half-Duplex).
What is working:
I can see the telemtry from the receiver
The inverter is also working, first channel is receiver output, second channel RX input on PixHawk, the receiver sends data to the PixHawk:
However the Pixhawk TX does nothing, it is high (second channel):
Any idea how to debug this? Why is the Pixhawk not sending any data?
Regards,
Sebastian
hosein_gh
(Hosein Ghanbari)
November 22, 2020, 8:42pm
2
Hi
I was fixed this problem on my QX7 with this configuration
SERIALx_OPTIONS = 0 (if using convertor like rs232)
SERIALx_Protocol = 10
Wiring like this post
If telemetry is not working till this step try to add 2 1n4007 diode before Vcc from fc to converter
Thank you very much, SERIALx_OPTIONS set to 0 did it
Never tried without 4 (half-Duplex) because it sounded logical and in https://ardupilot.org/copter/docs/common-frsky-telemetry.html#common-frsky-telemetry
It says:
" In general, F4 based autopilots using an external bi-directional inverter can use any UART with the following configuration:
SERIALx_PROTOCOL
=10
SERIALx_OPTIONS
=160 (enable pull-up/pull-downs on TX and RX pins for those external inverter circuits that may require it)
hosein_gh
(Hosein Ghanbari)
November 23, 2020, 8:03am
4
It good to hear that you got it working
Yes a little bit confusing but its for other flight controllers like omnibus f4 not pixhawk
Your right, I think that came from me trying it first with a Mamba F405 and then moving on to the Pixhawk. If I’ve finished the second inverter I try it on the F405 again.
Alberto_Ds
(Alberto Ds)
November 24, 2020, 12:56pm
6
Hi, I also have a similar configuration and the same problem, even putting 0 on serial option unfortunately I have not solved. Omnibus nano F4 v6.0 and radiomaster
Here are the tests I did, can I try anything else? Thanks
I bought a couple of these max3232 cheap china boards from ebay and the first one has worked for about a year and does not get hot, never tried the second one till this week. It was not working, so I put a scope on it and found some of the through holes on the board (where you connect the wires to on the end of the board) were not making contact. I had soldered the two diodes to the bottom this time and the wires to the top.
And the diode that is connected to the S.Port was open (because of the…
ThePara
(Cornel Fudulu)
November 24, 2020, 1:16pm
7
The MAX323 boards have two circuits, one on each side of the board. Make sure all your wires are using the same side.
hosein_gh
(Hosein Ghanbari)
November 24, 2020, 5:31pm
8
did you tried this ?
Problem solved by adding 2 1n4007 diode before VCC from FC to RS232
Alberto_Ds
(Alberto Ds)
November 24, 2020, 5:42pm
9
Not yet. This is my inverter:
This is my inverter. green tx to tx1 FC , grey rx not connect, red Vcc to FC. violet GND to FC, yellow to S.port RX, black to gnd RX
[inverter sport]
Alberto_Ds
(Alberto Ds)
November 25, 2020, 7:46am
10
Why 2 diode 1n4007? Thanks.
hosein_gh
(Hosein Ghanbari)
November 25, 2020, 7:58am
11
Some rs232 converters are not working with 5.2v
2 1n4007 will drop voltage to 3.2 to 4 volt and its will work
Alberto_Ds
(Alberto Ds)
November 25, 2020, 8:02am
12
Hi, thanks but if i have a 3.3V pad on FC (omnibus nano), can i try with this? Without diodes? My quad is micro only 3"
hosein_gh
(Hosein Ghanbari)
November 25, 2020, 8:08am
13
If you have 3.3v ignore this step
Alberto_Ds
(Alberto Ds)
November 25, 2020, 8:15am
14
Now my inverter it’s connect to 5Vcc on FC pad. Can i try to connect to 3.3 pad?
Alberto_Ds
(Alberto Ds)
November 25, 2020, 10:35am
16
Hi, don’t worked at 3.3V. I tryed protocol 4,10,23. Serial option 0,160. Baud rate 115,57. No new sensors on radiomaster.
hosein_gh
(Hosein Ghanbari)
November 25, 2020, 11:06am
17
i dint used radiomaster, is it OpenTx ?
Alberto_Ds
(Alberto Ds)
November 25, 2020, 11:14am
18
Yes, open TX.
I connect only pad TX1 on TX pad inverter, could that be a problem?
ThePara
(Cornel Fudulu)
November 26, 2020, 10:27am
19
If your FC is based on a F4, you need both TX and RX connected.
Also, you need a diode between the inverted Tx-out and RX-out, where your S-Port wire goes to the receiver.
flyespen
(flyespen)
November 26, 2020, 5:17pm
20
Have a look here, maybe it help you.
FrSky passthrough and Yaapu works fine (Copter 4.0.5 Stable)
Frsky Smartport Telemetry,
I use receiver X8R and Smart Port Connected Ground and Signal to Inverter (no 5v red cable)
Then from Inverter to TX4,RX4,5V&G on the F405-STD
SERIAL2_BAUD 57
SERIAL2_OPTIONS 0 (Its several options available now)
SERIAL2_PROTOCOL 10
[Max3232_3.3v_diode] [F405-STD Yaapu working, 5v from FC only][No 5V from receiver]
I ended up creating a new inverter with cabling to suit the pins on F405-STD. [1272825…
