Manufacturer / Brand / Manual
These power modules are local maybe and do not have a brand or manufacturer, they were just ordered from FlyRobo website. So I am unable to find the exact manual.
I tried looking it up online but only got results how long the FC waits for the Radio lost control. And found this only RC_FS_TIMEOUT.
And I still could not understand why in Battery Failsafe it would increase its altitude.
Regards.
Is the picture above a picture from YOUR power module or just a picture you picked up somewhere. If it is not exact that power module you have, why you don’t send a picture of yours.
If the module is a locale one, ok. But also in that case you can provide a link not only to a shop but directly to the product you bought.
Based on you last .bin file
the BATT_LOW_VOLT is set to 10.8V
the BATT_CRT_VOLT is set to 10.5V
the BATT_LOW_TIMER is set to 10s
the BATT_FS_LOW_ACT is disabled
the BATT_FS_CRT_ACT is set to 1 - LAND
but
the FS_OPTIONS only Bit 4 is set “Continue if in pilot controlled modes on GCS failsafe”
So due to these parameters failsafe is triggered if the voltage drops below 10.5 V for more than 10sec. But nothing will really happen due to the FS_OPTIONS setting.
If the shown voltage values are the correct ones I can’t say as I don’t know if and how you calibrated your power module.
You said that you did all correct but you didn’t read the documentation about battery failsafe. So I have a little doubt that you really did this. First Time Setup - Mandatory Hardware Configuration - Failsafe - Battery Failsafe
Please describe exactly step by step how you calculated and set the BATT parameters, especially following values:
Yes sir, the picture above is the same one that I have got,
Here’s the link
No sir, The power module is indeed set correctly. I only know this by saying that the HUD displayes the exact value(volts) that my voltmeter/battery charger displays. As said earlier, only current calibration is not done.
I’ve seen all these thoroughly but nowhere I saw that why would it gain altitude. Nor after what time it will trigger the failsafe.
My apologies if I missed anything
Regards
Sir you literally left after i mistakenly took a flight after thinking the new motors will help. You didn’t even considered. For the param files, I’m new to all this and a bit weak in terms of reading and understanding long blog posts. I try me best. If I were to read the documentation and solve my problems i would never have created this thread in the first place. If I am weak in some thing, and you know that, you should atleast do not leave me alone knowing that I have an important project. But you had to ask me to send you intermediate param files which I had no clue about. Only if there would be a post seen timer, you would see how many hours I spent on taking literal notes of your “How to tune your quadcopter methodically”. But still I am slow paced learner and I admit that. Yet, I have apologised every single time to all of you seniors. And yes, I am still sorry for asking help for a thing that is already available on a blog, or taking a flight when you did not advised. You all are great enthusiastic people, much ahead than a newbie like me. Nobody helped me like @dkemxr did. But I cannot do anything when you don’t reply. I daily struggle on my own, I buy stuff, replace things, troubleshoot, read this thread from the very beginning, and still there are always somethings that are going to offend you or dave. I am a slow leaner, weak learner. Do you know what will happen if you guys stop replying to me? I will fail my major. But this is a decorated forum. I cannot beg you guys also.
I again am sorry sir. I will try to follow the tuning blog again. You have all the right to not even give this a read and shut me off. I’ll take that even being sorry.
Regards
It is hard to believe you:
You now show a chinese crius module but you said you don’t now the manufacturer and brand as it is a local product. So what is it now. What is written on your module exactly. Why you don’t show a picture from that.
But nevertheless it is also possible to go on without this information.
How you in detail compared the voltage between the HUD display and your voltmeter. Did you measure the actual voltage at the same time with the FC / HUD and parallel with a voltmeter?
How you connected the voltmeter at that moment?
Describe it so detailed that a small pre school child or a senile senior like me can understand.
On the page I linked above is clearly writen:
"When the failsafe will trigger
If enabled and set-up correctly the battery failsafe will trigger if the main battery’s
voltage drops below the voltage held in the BATT_LOW_VOLT parameter (or FS_BATT_VOLTAGE in older versions) for more than 10 seconds. The default voltage is 10.5 volts. If set to zero, the voltage based trigger will be disabled.
Out of your questions I believe you didn’t read these simple information. As @amilcarlucas said, you didn’t follow the guide.
I can’t say why your drone gain altitude, your last log file only show that it was always in stabilized mode. So I assume you controlled it all the time.
But again before any flight and maybe any cost intensive further crash follow the guide.
To set the right parameters of the power-module you don’t need an extra amperemeter or wattmeter, you only can follow the instructions @dkemxr gave you on Mar 3rd:
All you need is a charger that provides mah put back in the battery and it’s simple to calculate a correct amps/volt value from the ratio of mah logged to mah re-charged.
So, charge your battery to full. Make a motor test run on the bench. Note the consumed mAh (CurrTot) Recharge the battery again to full. Note the recharged mAh.
Due to your last log the old amps/volt [BATT_AMP_VOLT] = 17
Calculate: new amps/volt = 17 * recharged mAh / consumed mAh (edited)
You started this thread 11month ago. A long time to read all information.
I first time noticed Ardupilot during September 23.
So I am a newbie as you but I am learning a lot just by looking to your problems.
You are young and flexible, so you can also do it.
Alright, one more comment about the battery and forget about it. In the last log you posted it was not at full charge (only 11.6V) when you started or you screwed up the voltage calibration. I don’t care which, figure it out for yourself ,we have given you all the info required:
Your other major problem is the outputs are oscillating. It could be because you did not set all the Rate PID parameters as suggested. This is what that looks like:
So, because you have not shown that you can follow instructions given I’ll post a parameter file here that you can simply load to update the required parameters. In Mission planner go to the Full Parameters List Screen, select “load from file”, pick this file and then press the “Write Params” button.
Fully charge your battery and/or calibrate the voltage sensor and then make another hover flight in Stabilize for ~30 seconds. Don’t bounce it off the ground, don’t make multiple take-off attempts. Get it in the air and then land. No more flights, just one and then post a link to that log file. f450.param (190 Bytes)
Sir actually there is no brand written on the module, its just bare pcb, I’ll post a picture in few hours if that’s the case. Also, We ordered from the same link which you say chinese.
This is accurate and maches with my skyrc B6 charger volatges. I used voltage from this and entered into the battery calibration voltage tab of mission planner.
Sir I know the 10 second timer(that is for low batt volt), I am just confused that when only my critical batt voltage was set to 10.5 volts, then how after 30 seconds it triggered the land. Maybe I’m still missing a param that;s there for this.
It could be due to high vibrations, I will test this tomorrow morning sir by enabling battery low voltage failsafe.
Yes, I have this noted down, just wanted to ask, that I can reverse the props and run them at max speed for this calculation right? Or should I take a flight and then proceed?
Sincere Regards.
I copied that from a previous post where I said to also update the Roll values to the same. I assumed this would be obvious. But no matter, just load the parameter file I posted and it will do it.
My consumed mah in currtot after a flight, shows, 470.33
Battery charger shows mah put back in battery as 841 mah.
So, 17 * 470.33/841 = 9.50
Am i correct?
Regards
You went to a lot of work editing those intermediate parameter files by hand.
You edited every single value and changed it to the value of that parameter on your board.
Because your board is mostly unconfigured, you basically unconfigured the intermediate parameter files.
That is not the way to do it. The way to do it is:
Concentrate on the basics, start with only these files:
02_imu_temperature_calibration_setup.param
05_remote_controller.param
06_telemetry.param
07_esc.param
08_batt1.param
10_gnss.param
12_general_configuration.param
13_logging.param
14_pid_adjustment.param ← this should contain the parameters and values provided by Dave
16_notch_filter_setup.param
Start with the first file and go one by one. Read comments above each parameter, make a decision how to change the parameter to suit your needs, change the parameter value, change the comment after the parater to explain your decision
Use the mission planner to compare and load the parameter changes into the flight controller.
Ask questions if something is unclear. Do not move to the second file until the first is completed.
To, @Juergen-Fahlbusch and @dkemxr sir.
Yes, but I actually sir dave asked me not have landings and perform 1 flight of 30 seconds, but due to wind conditions, it was not so much stable, and it was not holding its altitude, even when the throttle stick was in the middle, it was coming down, tried to keep up with the sticks, it was drifting quite much. And due to this, i ended up having 2 flights, with few landings in between and 1 or 2 crashes.
But then too, I am still attaching the logs. Both Flights were taken in a wind speed of 10.6km/h in the Northwest direction. Maybe not a good day to start with this. Also, dave, I recalibarted the power module, I saw that in both logs the voltage starting value is somewhere close to 12.3 or 12.4. But on the HUD it displayes 12.6 only. Am I missing something?
Regards https://drive.google.com/drive/folders/1Gv4Bb8WlMuELfAB41wAF7tMBjxq7MjGl?usp=sharing
