Turn off blh auto telemetry - it’s causing the CRC errors
See the PR I reference above, it includes a fix for the rpm calculation which is currently wrong in 4.0
That’s strange. You might be better turning off debug in that case.
i will try to get to it later. i actually found a gecko3 frame i had - need to donate away 3/4 of my projects pile - so it flew amazing this morning. now i think what else to put on this kakute 3" frame. some front collision avoidance would be neat, but, most/all small i2c sensors are less than ideal.
and, RPMs are dead on - no issues, if you wandered about that. means are: 8281,8562,8300,8485.
i sat it on matek rubber posts and used provided rubber inserts - so, vibrations are with mean of 4, max at 11. pretty great for a small controller.
only baro location on top is not ideal - difficult to cover it.
also, just to confirm - i did not use yet the ESC they packaged FC with, i soldered it on the model that had older esc with a 32.4 blheli32 code - so, it worked perfectly fine with passthrough, i was able to connect to it from blhelisuite32.
gecko3kakute.param (21.9 KB)
Yeah I think some of the problems with blheli we are seeing are related to later versions
It’s a great board. I have it mounted on the top of my forward stack and a big bit of foam fits nicely between it and the top cover
Paathru has been flaky for me. I think I had to configure Dshot, press calibrate and then connect twice from blhelisuite. I also had weird ESC behaviour which turned out to be because I was overtaxing the BEC on the FC - I stopped powering the camera from the FC and all was magically good again.
I stay on 32.4. they were fixing different issues with newer ones, but on 32.6 color leds did not work correctly, and frankly i did not have much desire to do full regression test of other issues.
in the blhelisuite_32 you should see the dropdown on the right, and it offers all those versions. at least it should.
well, it is a flame war topic. i like tekko32, but, it is not bulletproof. nothing is bulletproof, all escs can burn.
it also depends upon format.
if you`re making a larger model - my recommendation is to use kakute f7 AIO and use discrete separate ESC modules, not the 4in1 brick.
for models we talked about here - small and ultrasmall - -there was never much choice at all. there was only 1 controller to use with 20x20 mount format - omnibus nano v6, and it usually was paired with Ori32 25A esc. not reliable at all, and not perfect, but, nano v6 worked very well with it. now we have this new great kakute f7 mini - it is a new best thing for small models.
usual culprit and an additional complexity was to find ESC that actually works with 2S lipos at min voltage. that i did not do myself much, as i did not make any 1 or 2 S models, i only played with fast ones - 3S and 4S.
i used those:
http://www.holybro.com/product/tekko32-f3-esc-35a/
http://www.holybro.com/product/tekko32-f3-4in1-40a-esc/
out of 4in1 ones i had 4 of them, one of them burned out. 3 others are fine. single ones never had issues. of ‘kotleta’ ones i have no clue, not sure what is the benefit, if any, i like F3 based ones better.
that`s a big one, here is what i just did today - transplanted kakute mini into this one, my current favorite, gecko 4".
it flies on 4S 850mha, quite stupidly overpowered, and a lot of fun. may be worth swapping ESC on that one from 25A to 45A, but, will see. those motors i think max out at 12A or 8A, but, i just do not like Ori32 that is in there - it lies about current badly and shows voltage as .2V lower than real. not the end of the world, but, annoying.
could you please post export of all params from the 3" model where that ESC driven harmonic filter is enabled? it would help to have a reference to see what all options are supposed to be set to.
i just flew my 4" model with the kakute mini - it suffers from spike of vibrations at high speeds, 3" was not like that at all. i want to try this notch filter prior to tuning it.
set up BLHeli telemetry and make sure you have the number of poles set correctly. Then set:
INS_HNTCH_REF = 1
INS_HNTCH_MODE = 3
INS_HNTCH_ATT = 30
INS_HNTCH_BW = 50
INS_HNTCH_FREQ = lowest frequency you want to cover (e.g 100)
The defaults for ATT and BW are also probably ok, but for your size copter the above might be better.
does the INS_NOTCH_ENABLE 0 0:Disabled 1:Enabled Enable notch filter
also needs to be set to 1?
also, for the “set up BLHeli telemetry and make sure you have the number of poles set correctly” - is there a step by step guide for this, what is actually meant by ‘number of poles set correctly’? number of poles is set to ‘auto’ in blheli32 esc configs. there is nothing in there for telemetry parameters
Number of poles refers to the number of arms on the stator.
At least that’s what I think… Because the magnets can also be referred to as poles… I’m using the stator number, but maybe we need clarification.
well, i am perfectly aware of how many poles my motors have. i do not follow where/how it is expected to be set for this new feature and what are the exact blheli related pre-reqs for this thing to work. and how it can be confirmed if it works or not.
it is in the master now, i pulled it and compiled, flashed - i do not see much of a difference from how it flew before - so i suspect it is not working, probably. but not sure how to confirm.
i suspect there is more in some non-obvious settings for that to actually work, as i do have esc telem flow getting for sure, get the current/voltage from it - but MP never shows me any data in its interface for any of ESC telem channels. go figure.
I think he means this parameter:
SERVO_BLH_POLES
But, if the default is 14, that’s actually the magnet number, not the stator number.
I want to try this soo bad! I’ve got my copter loaded w/ the new firmware, but have been to busy to test it.
So, I don’t have any more info for you… I’ll wait for others to reply…
MP doesn’t show me any data either in most places… But it’s in the logs… I know it’s working. (not the whole filter thing, but BLH telemetry is working for me)
well, there is one more monkey wrench thrown in here.
most recent master somehow broke the logging in the kakute f7 mini. it no longer capable to see and download logs - it worked for sure using previous compile. what the heck…
will try to update MP now but i do not think it is MP, it is probably the new master. nope, no use. still gives same error -
Getting list of log files…
Error:System.TimeoutException: Timeout on read - GetLogEntry
at MissionPlanner.MAVLinkInterface.GetLogEntry(UInt16 startno, UInt16 endno)
at MissionPlanner.MAVLinkInterface.GetLogList()
at MissionPlanner.Log.LogDownloadMavLink.b__12_0()
so, error is normal if there are no log files on the device. with this new compile logs are no longer created. damn.
