3" Gecko with 4s. I have some 1300mAh that I am using at the moment but have ordered some 850mAh to reduce the weight. It’s got a runcam split 3 micro on it as well which is pretty sweet - only problem is that the 1A BEC on the Kakute Mini is not enough for everything, so I am going to have to carefully power the split from the LiPo with the addition of a TVS diode.
All up it’s 334g with the battery. Smaller battery, maybe 300g - GPS puck is contributing to that as well as the longer 4s wires
If you look in the gitter - some guy did a fork with an implementation of a protocol to control split. Would be nice to be able to turn it on/off and to video/photo modes from a taranis switch.
I just looked at split 3 specs - it can feed from up to 20v. Why not to feed it from lipo? Just make sure to solder capacitor on feed line, as usual
It explicitly says not to in the docs, but I have no option. I have a 470uF 25v on the battery and the feed will come from there, so should be ok, but I am going to add a TVS just to be sure.
Yes, given time I will wire up the runcam serial port and get hacking
i added the motor pole param and i am under the impression it returns the actual shaft rpm as is. using a 2200kV 14 pole motor on 11,2 volt i do get ~24500 at WOT with no load.
One is cause by BLHeli passthrough - if you use passthrough then make sure you reboot afterwards otherwise you get the 0x8000 error. Same for running BLHeli test
hmm, i can check again, but i think i synced with master on yesterday`s evening or so. may try to do it again.
i never had errors on kakute in relation to pass-through - why would it error now? i simply used same exact config i had on previous models, kakute and omnibus nano - never had errors on them.
i also got it all working, got esc telem working and showing current/voltage from esc, just made a mistake and bent props - and now need to wait until spare props will come from amazon. but, all worked, s.port feed into taranis worked.
nice little controller.
Cool! If you have telemetry working on 4.0, any interest in trying https://github.com/ArduPilot/ardupilot/pull/12544 to give me another datapoint? I haven’t flown this beyond a hover because of work/weather but initial indications are amazing.
