yes, confirmed set to 6. 4th time using this digital ESC.
oh, okay, I see. thanks.
Then I donât understand why thereâs any effect at all when using different Minimum/Maximum Throttle values. Is it reliably reproducible?
Do you have something like this in Messages:
RCOut: PWM:1-8 DS600:9-14
No, today I tried to set it back to 1100-1940 again, Motor test at 1% throttle, same as yesterdayâs 1040-1960 behavior. previously I have not done a motor test at 95% throttle. after setting 1040-1960, then I did the 95% motor test throttle.
Yes.
I think I wouldnât worry about it then, as long as you donât notice other abnormal behavior. You could try setting very high values just to test and see if thereâs any noticable difference (without props attached of course). But it really shouldnât have any effect as long as DShot is used.
this RCOU.C9-C12 does not look comfortable to me.
Sometimes M4, sometimes M1 will spin much lower than the rest of the three. there will be one motor spin slower from the rest.
I have added these settings as well.
ATC_RAT_PIT_SMAX,25
ATC_RAT_RLL_SMAX,25
ATC_RAT_YAW_SMAX,25
PSC_ACCZ_SMAX,25
