Last I checked avoidance only works in Loiter, not PosHold. That was the case when I was testing an A2 lidar.
A question for Patrick im revisiting my avoidance project and would be very grateful if you could please give me the 2 sets of numbers to write for serial and I2C fo the TF mini,many thanks and thank you for this project
Hello Martin
There are 3 models of TFMINI now
What model do you have?
how can you tell what model you have.
Hi Patrick it was the 1st TF Mini that came out and thank you for your time
I thinks you are referring to this
Hello to all, i have a similar request.If anyone could explain how can i pass the command to revert back to serial once on I2c. Using TFminiPlus. Please, and thanks in advance.
Here is an interesting offer from Benewake for anyone who wants to develop and integrate Benewake product free evaluation activity for developer
hi, i got a question for you. did you have a chance to look at this product:
http://www.mateksys.com/?portfolio=3901-l0x#tab-id-2
i got one board long ago with a F765 sent for evaluation - it is a combined optical sensor and L0X sending data over serial interface.
http://www.mateksys.com/downloads/setup_optic%20flow_in_INAV_rev1.pdf
i am not sure - do you think it is practically usable? L0x is very short range, but they added PMW3901 into the mix. theoretically it could help in optical flow position hold, but how well does that PMW3901 actually work?
Yeah it is similar to http://www.proficnc.com/all-products/185-pixhawk2-suite.html but on serial.
This particular device is limited to indoor with max height of 1.5 Meter,making them pretty useless,
Thats cool
Can’t wait to see it working
I wish Benewake had CAN version of these lidars.
Just use a CAN module to interface the TFMINI serial, it works OK
Hi Patrick,which can interface module would you recomend please.many thank’s in advance
There was some discussion here:
here:
and here:
Think I will order one from mRo and give it a try,thank you Patrick
Good day, i advice you the mRo can node… just check also when you will receive the version of the firmware… you can use rangefinder on rangefinder firmware and also with the universal firmware.
Thank you for this may contact you when it arrives
