- Are you streaming at 1080p or 720p?
- Please try SIYI modified QGC. You can download it in the ZR10 page.
Thanks @champ8242 and Frank! I installed Happytime RTSP on the Herelink but the issue is similar to VLC or Qgroundcontrol.
I think that most important things work now, with the Siyi QGC app. @SIYI , where is a good place to ask questions about the Siyi QGC? For example I have a notification of Terrain Load Progress that does not go away and I am sure I will have other questions regarding this.
Check here
Still waiting SIYI to share the source of the modified QGC you used. You developed it with a shareware version of QT so you have to re share. If you donāt you break the rules about sharing the QGC is released under.
VLC is pretty bad for low latency streaming with any RTSP feed. It has a default 1000ms buffer, you can make it lower but Iāve found it becomes unstable below 150ms whereas QGC doesnāt have that issue.
You are posting now your question muliple times in various topics without success! Donāt you think itās time now to move on instead of flooding your frustration to other users?
Iāve answered the same questions in the QGC thread. There is no update so far.
After the holiday, Iāll check for more updates.
Just to be clear, I will only reply to QGC questions in the QGC thread on ardupilot forum. I donāt know why it is so difficult to post relevant questions in relevant discussions.
Dear @SIYI I would like to report 3 issues with the camera:
- Sometimes, without a clear reason, but definitely after keeping the camera on for longer than 30min, the buttons on the Siyi app do not work any more. Restarting the app fixes the issue. I do not know if this is related to the app or the connection.
- Just after takeoff, if the camera is focused on something close to it (grass for example), it will not focus to infinity on its own. Zooming fixes this. It should search for focus on its own and I should not have to zoom to get the camera to focus.
- I cannot pull the RTSP stream to a second device, therefore my only way for now to share the video stream further is to share the ground unit screen of my HereLink. Could I pull the camera RTSP stream directly to a second device that would be running Windows or Linux if I would be using your MK15 or MK32?
Forwarded to the team. Will update asap.
I think it is possible. Welcome to have a try.
I have an issue on one of camera, zoom works fine, gimbal controlls doesnāt work, ardupilot returns error: PreArm: Mount: not healthy
Connected by serial port, if i replace it to another same camera, gimbal starts to work fineā¦
Any ideas of camera is defective?
All firmware updated to latest version
ā¦
UPD: after few minutes oof working it starts to blink RED RED Orange and camera firmware becomes FW VER: 0.0.0
Updating doesnāt work⦠looks like defectiveā¦
Hi @SIYI ,
I just wanted to let you know of another issue I found, that mostly happens after the aircraft moves a bit faster in attitude, but not necessarily. It is quite bad to see the gimbal slowly pitching and rolling for no apparent reason for up to 10 deg. I uploaded here 2 videos, one from a hover and another after a flight. I would have expected the movement to stop when the aircraft is not flying but it seems to not be the case.
What can I do anything about it? This issue is not frequent but can easily be replicated.
Hi @SIYI !
Weāve got another problem during the last test. Bad stabilization of the gimbal during flight. Color ācodeā (leds) of the gimbal shown the problem with heating of the electronics. The temperature was -2 C.
We havenāt changed the heating settings.
What is your suggestion?
Please show us a comparing video with same settings: Same controller, same model, same firmware version.
Did you lost video when it blinks like this?
Please show a video. We need to see how exactly the bad stabilization is.
Checking and will answer asap.
Should I ignore the other two videos?
I deleted the old videos, so now, there are only 2 related to the issue I talked about yesterday.
Thanks
Hi!
I have two cameras ZR10.
Very bad stabilization. Even on the table!!! Angular vibration range 0.01 it is not true! How did you measure it!!! Is not true!!!
Optical unit froze at minus 3 degrees Celsius! Zoom and focus not work!
At negative temperatures, mechanical vibrations of the gimbal occur. There is no hardness setting in the program. Self-oscillations occur.
The auto-record button is not saved in the program.
I think gyroscope calibration and temperature control will not help you. What to do with the rotation of the Earth? And vibrations that VERY affect MEMS. The biggest difficulties with the horizontal stabilization plane. In it you donāt have a direction reference signal. You can see it in the gimbal. Your IMU composite filters donāt work well. In flight, the corners constantly āfloatā! Especially the yaw angle. Cannot use high zoom.
I have last firmware.
Bad support on email!
Hi Alex,
We never received your complaints to ZR10 anywhere else before this post. And I donāt think I ever offered support to you myself. Please confirm who was supporting you.
If you think there is a problem to stabilization, the best way is to show us a video. We cannot offer support based on imagination.
Please try to show us all the issues you concern by video, thanks.
Best regards,
Frank
Hi Frank,
I asked a question about the control code via S.Bus. Iām аlready figured it out. With video is problem. In total, I committed two flights with ZR10. In one the camera is frozen. In another, writing to flash did not work. I recorded only a small part of the flight with the player. Say your e-mail and i send it to you.
Please write to support@siyi.biz and I will see. Letās solve your problems one by one.
