Can you suggest me the proper configuration of frame size, Motor KV rating and Prop size for adding a decent gimbal and camera
A subscription to eCalc will save you from buying the wrong hardware.
Hi Dave, I have decided not to use the gimbal and removed the battery from the camera and have powered the camera directly from the lipo battery using a 5v bec, The weight has been significantly reduced. Since there is no gimbal to stabilize, the video is getting choppy, is there any way to solve this
Other than FPV Iām not much of a video guy. If I need that I fly the DJI craft.
Thank you so much dave for spending your time with me
All my doubts has been cleared
One more thing dave how did you get a graph like this, The throttle out and rcout are two different graphs with two different min and max values, i mean the thout is even in decimals, how did you manage to appear them side by side like that
Left-click on one series of data, like Roll in this graph
Then right-click on another series of data that requires a different scale, like Volt in this graph
Thank you shawn, that worked
