The press the “Del” buttons and remove the parameters that does not apply to you.
Good.
Even if integrated, it still needs to be configured, if you do not configure them you will probably get some problems later, problems like the ones you are having NOW.
Those X Y Z GNSS positions are clearly documented in the wiki.
Yes you can not do it until you have completed the missing steps above.
Update to this exact ArduPilot Methodic Configurator version:
You did not update the “Notes” on the Component Editor window. I also do not think you have 3’’ props
You did not update the “Change Reason” in file 02
File 04 is fine
05 NTF_LED_TYPES should be 231
On 05 the BRD_ALT_CONFIG “New value” must be set to 0
On 05 the RC_OPTIONS “New value” must be set to 32
The other values are borked as well
08 you missed this one completely
10 was a mess, this one I fixed for you using the “Add” button.
12 was OK
13 OK
14 OK, but without thrust stand you can not be sure.
15 You seam to have ignored this one completely, that is only 20% mandatory, so it’s OK
16 OK
17 Completely missed the point!, What have you done here???
Methodic4.zip (509.1 KB)
Here is my file, I trying to fix everything as much i as I can understand. About 15 and 17. I can’t lift from the ground, so i cant even take information for that, reason i can’t lift is vibration and oscilation.
I just noticed that the temperature compensation values are all wrong.
You need to upload the new 02 file that I posted above and re-do that calibration.
This time please do read the Blog post, it contains very simple step by step instructions for the temperature compensation.
The temperature calibration results are correct now.
I fixed a lot of stuff and created a “X11_plus” template on the tool. Please download install and use the latest 0.6.0 version
On the component editor:
Telemetry > FC Connection > Protocol - I think you want Mavlink 2
Battery > Specifications either the Chemistry is wrong or the voltage per cell are not correctly set.
I fixed a lot of stuff in the component editor please review it and re-do the configurations starting on file 05
I think the battery monitor BATT_AMP_PERVLT and BATT_VOLT_MULT are wrong.
I advise against EK3_SRC1_POSZ,3 and FS_EKF_ACTION
After re-doing all the steps 05 to 19 (and skipping 11) you can start on the 20 file.
and add a “vehicle.jpg” file with a photo of the vehicle.
I have been updated your program, and now just turn on till components. i press save and start and ir turning off. I will fix telemetry, And about batt_amp_pervlt I don’t have device to measure it correctly. Okay, i will fix ek3 too. So now after all those I should takeoff from the ground?
@amilcarlucas Hello again, Look like I pretty much done as much as I understand and could. I’m wondering later about quick tune, i saw there is for VTOL. can i use it? And I saw pid adjustment.py. I never used scripts before, how I could do so and which one would be okay, for my copter? Here is file.
The Quicktune is for both VTOL aeroplanesandmulticopters.
Yes, you can use it, it works great.
You do not need to use it because you did change the parameters by hand. I assume you tested the parameter changes you did in the 15_pid_adjustment.param file that I created with the values you had in the 0000087.bin file.
Again the trick is to read the 20_quick_tune_setup.param documentation links in the top of the ArduPilot Methodic Configurator and watch the video.
