I take back what I said about my parameters being default as I started with a copy of my Nimbus VTOL parameters. I’ll edit the post above.
Here are the differences I see between my params and Wasim’s from MFE. My value shows first and then Wasim’s value. I haven’t checked to see if there are any critical params in the list so I’ll probably comment in parens () later on what I find. Feel free to comment.
ARSPD_FBW_MIN,12 vs 12
ARSPD_FBW_MAX,22 vs 26
BRD_SER1_RTSCTS,0 vs 2
EK3_ENABLE,1 vs EK2_ENABLE,1
KFF_RDDRMIX,0.5 vs 0.65
LIM_PITCH_MAX,2000 vs 1500
LIM_PITCH_MIN,-1500 vs -2500
MIS_TOTAL,0 vs 9
MNT_RC_IN_TILT,6 vs 0
MNT_STAB_TILT,1 vs 0
MNT_TYPE,1 vs 0
NAVL1_DAMPING,0.75 vs 0.85
NAVL1_PERIOD,19 vs 20
PTCH2SRV_D,0.04 vs 0.221
PTCH2SRV_FF,0.4 vs 0
PTCH2SRV_I,0.15 0.3683333
PTCH2SRV_P,0.7 vs 2.6
PTCH2SRV_RLL,1.15 vs 1.3
PTCH2SRV_RMAX_DN,0 vs 120
PTCH2SRV_RMAX_UP,0 vs 120
PTCH2SRV_TCONST,0.5 vs 0.3
Q_A_ACCEL_P_MAX,110000 vs 56296.96
Q_A_ACCEL_R_MAX,110000 vs 51412.85
Q_A_ACCEL_Y_MAX,20000 vs 27000
Q_A_ANG_PIT_P,6 vs 7.757376
Q_A_ANG_RLL_P,4.5 vs 8.59776
Q_A_RAT_PIT_D,0.004 vs 0.01318255
Q_A_RAT_PIT_I,0.35 vs 0.2904768
Q_A_RAT_PIT_P,0.35 vs 0.2904768
Q_A_RAT_RLL_D,0.004 vs 0.01058215
Q_A_RAT_RLL_I,0.4 vs 0.3333369
Q_A_RAT_RLL_P,0.4 vs 0.3333369
Q_A_RAT_YAW_D,0.07 vs 0
Q_A_RAT_YAW_I,0.08 vs 0.018
Q_A_RAT_YAW_P,0.7 vs 0.5
Q_A_SLEW_YAW,3000 vs 6000
Q_ANGLE_MAX,4000 vs 3000
Q_ASSIST_ANGLE,30 vs 45
Q_ASSIST_SPEED,10 vs 14 (Stall speed is 10m/s, should be below ARSPD_FBW_MIN)
Q_LAND_FINAL_ALT,8 vs 6
Q_LAND_SPEED,50 vs 70
Q_LOIT_BRK_ACCEL,50 vs 250
Q_M_THST_EXPO,0 vs 0.65
Q_M_THST_HOVER,0.5 0.35
Q_TILT_MASK,3 vs 5 (different servo setups)
Q_TILT_MAX,65 vs 35
Q_TILT_RATE_DN,50 vs 10
Q_TILT_RATE_UP,200 vs 45
RLL2SRV_D,0.08 vs 0.305189
RLL2SRV_I,0.2 vs 0.3805394
RLL2SRV_P,1 vs. 3.590459
RLL2SRV_RMAX,0 vs 120
RLL2SRV_TCONST,0.5 vs 0.3
RTL_RADIUS,60 vs 90
SERVO2_FUNCTION,80 vs 79 (this is just a different servo setup)
SERVO4_FUNCTION,79 vs 80
SERVO5_FUNCTION,33 vs 75
SERVO6_FUNCTION,34 vs 76
SERVO7_FUNCTION,35 vs 0 (uses SERVO11_FUNCTION)
SERVO8_FUNCTION,36 vs 0 (uses SERVO12_FUNCTION)
TERRAIN_ENABLE,0 vs 1
THR_MAX,70 vs 100 (on higher powered models, 100% is too high)
WP_LOITER_RAD,100 vs 45 (depends upon goals)
WP_RADIUS,40 vs 110 (bigger is probably better here)
YAW2SRV_INT,0.3 vs 0.15
YAW2SRV_RLL,1 vs 0.8
