I have an F450 drone that is using EMAX Pro 2810 1150kV motors, 51A DShot ESCs, and a 4s battery, and I have been having trouble dealing with a terminal vibration issue. When the throttle is increased (to about 50%), the drone starts vibrating very severely. The logs show that two motors at any given time have vastly different PWM values (~100-200), and when one increases, the other decreases. I believe this to be the reason for the vibrations but would love to hear others’ input. The drone is unable to fly, and when I increase the throttle even more, the shaking increases as well. I have linked two recent test logs here and here and would love to hear any potential causes and/or fixes for this issue. There are no loose parts, and the vibrations only happen when propellers are attached. I have also balanced the propellers. Would differing PWM values cause vibrations? The motors that differ are usually the ones that spin in the same direction. My setup did work for a day very well and with no hiccups, but since then, I have not been able to get the drone off the ground. Any help would be appreciated. Thanks!
