Hi all
very interesting thread. Maybe I missed it but would it not make sense to have a table where everybody buts his measured/tested MOT_THST_EXPO values in with all the measurements?
I would be interested in the following setups:
7inch HQ triblade - 1800kV Xing -Holybro Tekko32 Metal F4
7inch HQ triblade - 1500kV Xing -Holybro Tekko32 Metal F4
T-Motor Carbon P18*6.1 - T-Motor Antigravity MN5008 KV340 - APD 80F3
There is this discussion and there’s a table Tridge has to save the new data. I’m tracking it too, in case we can improve the motor thrust expo calculation in the Initial Parameters.
I think it’s on hold while some improvements are being made but I believe the script is totally safe to run, you just need quite some altitude.
Thanks Shawn
I saw that thread but thought its on hold. You think I could try the script with my overpowered 7"?
I will put ATC_THR_MIX_MAN to 0.2 to be on the safe side. Any other parameter to look at before running it?
I tried that on my 7" and at it’s current Rev level it maxed out the Expo value. Think you need to wait for further updates as you alluded to.
