i built a little big drone i m using default parameters and initial tune parameters. Motors, props and platform are straight. i did acc and compass calibration well. i m using 2x gps with disabled compass. i m using only internal compass from FC. well balanced CG. total weight almost 80kg with batteries. Using Motor İnterlock for safety.
Motor pwm set to 1050-1950
Throttle range 1040-1950
Radio sticks centered.
Radio calibration, motor orientation, prop rotation, stick response done.
My setup;
Cuav x7+ pro
2x Neo 3x Gps
6x X11 Plus motors 43x14 props
Total 14s36p li-ion pack.
Here is the logs and take off video.
(tlog is long. you can check last %10 percent)
Drone doesn’t seem to be leveling itself, or it’s doing it very slowly. am i right?
To configure big heavy drones you need to follow checklist procedures to make sure you do not miss a step.
Is the ESC RPM telemetry configured correctly?
This is not a hobby vehicle, this is an expensive professional vehicle.
The Manufacturer specs are PWM 1100-1940, correct that. And add ESC RPM telemetry.
AMC is very well documented. You need to read and follow the instructions it presents you.
This is an expensive machine, read the instructions carefully, and ask questions.
if i calibrate external compass without mounting on drone, (i mean calibrate sperately from drone frame) is it work correctly? because drone is very large.
amc is step-based and it helps in everything from hw setup to final touches.
go step-by-step. only you may skip the initial steps of like imu calibration etc which you know are correct. do the other steps
@amilcarlucas AMC saved me. What a beautiful helper. Thanks a lot man. Good job.
2nd take off successful. Here is the take off and log files. Based on herevit x11 template. İ will continue to tune tomorrow. I m waiting for your advices
i will test AltHold and loiter modes tomorrow. but its huge bird. so i don’t want to do anything wrong or leave anything incomplete. Can you give advice based on the logs for more stable takeoff?
Are there any parameters I need to change before applying autotune?
I can’t draw any conclusions from the logs. Could you do a simple analysis? ArduPilot has changed a lot since I last used it. i need some advice from Masters before next flight.
I don’t know where you are in the AMC but the attitude stability is very poor. It must feel very sluggish in flight. I highly doubt Auto Tune would run w/o failure to level errors in this condition.
