I think you need to start your own discussion for all this, rather than put it all in the Harmonic Notch general discussion.
Start your own discussion since this is not related to the harmonic notch filter
check my notch setting comment any suggest
frame : own made 450mm
fc : pixhawk 1
esc : 35A 2-6S Blheli_S DSHOT600
motor : ready to sky 2212 920kv
https://drive.google.com/file/d/19Z0N6dL-oLxSIkU5rJy2vSz_BAdPkykZ/view?usp=sharing
For DSHOT to be effective you need to use the AUX outputs for motors, not the Main outputs.
I would advise to use the bi-directional DSHOT firmware, then set the HNOTCH to use ESC RPM data:
INS_HNTCH_MODE,3
The params I recommend below can still be used if you get DSHOT working.
Look for a message in MissionPlanner Messages like:
RCOut: PWM:1-8 DS600:9-14
With the existing config, set these:
INS_HNTCH_REF,0.16
INS_HNTCH_FREQ,77
INS_HNTCH_BW,38
IINS_HNTCH_OPTS,0
INS_HNTCH_HMNCS,7
INS_LOG_BAT_MASK,1
INS_LOG_BAT_OPT,4
Please also set
BATT_FS_CRT_ACT,1
BATT_FS_LOW_ACT,2 or 3
EDIT:
INS_HNTCH_FM_RAT,0.7
JazzMaverick BLHeli_S firmware flashing old ver J-H-30, 16.7
motor pin move to main pwm to aux just setting changes servo output 9,10,11,12 motor selection
BRD_PWM_COUNT not showing SERVO_GPIO_MASK = 0 motor aux work
after weekly holiday test fly
Donât use the double-notch
INS_HNTCH_HMNCS 3 ok ?
after all setting change esc rpm showing in log ?
Depends on what your FFT shows. 3 ok for two-blade props
today flying
after switch poshold hold,loiter,land mode quadcopter climbing high
compass/motor calibration Done interference 30
frame 450 fc pixhawk 1 gps m8n
error
ekf variance
vibration compensation on/off
gps glitch or compass error
mission planner screen recorder and bin file attach
https://drive.google.com/file/d/1sy6TCHgjc63EE0EwYFB64iSFTrc4l5ub/view?usp=sharing
https://drive.google.com/file/d/1nvwrHUTgTzsKM0FKyy4SCajnriYH5nwZ/view?usp=sharing
@dkemxr last work changes
965 topic
after facing problem
next all change default normal
sd card format ,install plane firmware and again install copter firmware,blheli firmware default, motor output pwm . notch disable
and today fly again same issue
There is definitely high vibrations and your flight controller (IMU) is sensitive to these levels.
I would say you need vibration values below 15, it looks like every time it goes over 20 you have trouble.
No amount of software filters will fix this - you need to do more to reduce the physical vibrations or isolate the flight controller.
Plus you have other problems too
So try doing all the mandatory calibrations again, go outside and wait for a good GPS 3D Fix before doing the compass calibrations.
Or get a new flight controller.
today fly after all reset default all tuning setting default
but same issue only stabilize mode work
poshold,althold,land mode going high vibration after roll/pinch rc input
https://drive.google.com/file/d/1MhpzBNnZ-80_ISSEuI6EuKjs3g_X8prI/view?usp=sharing
https://drive.google.com/file/d/1NuUT3Y3b-0gLolddNtcodSHs1eoaORb0/view?usp=sharing
cant buy new flight controller
can other option any eternal sensor, peripherals buy and mount
Did you change the wsy the flight controller is mounted? Or do any other physical changed to reduce vibrations?
Foam tape is insufficient for this craft, you need something much more compliant like a ball mount. Even Zeal Gel would probably not work but you could try it.
Are those aluminum arms?
Yes almunium arm and base f450 frame
Extra battery and fc mount wooden plate
New shock absorber added
I feel your cables/modules above and surrounding the FCU are creating unnecessary vibrations. consider securing it down.
My 2centsâŠyears ago we used a hex copter where clearance between props tips was 1" or less⊠it was horrible to land and would eratically move up and down as it neared groundâŠit is partially why i started building my own coptersâŠmy designs are all run through ecalcsâŠthe x8 and quads are all ±18" square to motor center with 12 1/2 to 13 inch props⊠ecalcs flags a couple of these because they miss clearance by 1/2" or less⊠i.e. they all have 5" or more between prop tipsâŠi have yet to see any of them have issues with ground effect⊠not sure the reasoning⊠or if this has an effectâŠbut with the help of this community all 4 of my uavs are still flying with no major issue to date
Last night flight all setting test
3" Cinewhoop with duct 3045 prop
