probably turn rock solid here then thanks for letting me no
My dynamic harmonics PR has been merged into master: https://github.com/ArduPilot/ardupilot/pull/14470
If you are using ESC telemetry then I would definitely recommend using this:
INS_HNTCH_OPTS=2
This gives you a notch per motor. You will also get a big benefit by raising the BLHeli t-trate (SERVO_BLH_TRATE), I am using 100Hz on an F7 without issue.
This change significantly reduces the noise generated by the notches, so you should also find that if you re-tune with it on you will get a much crisper tune.
With FFT you should also get better results as it will track all 3 FFT peaks, although this is more applicable to larger copters so not necessarily worth it on a small racer.
Finally if you touch nothing, you should still get lower noise/better performance from the increase in notch update rate and the fact that the low-pass filter is now run last.
Happy Fatherâs Day!
So if I was using Double notch, disable that and enable âDynamic Harmonicâ only? If it makes a difference Iâm using FFT not ESC telemetry.
Itâs a bit mask. So you can set it to 3 to use both.
Knew it was a bitmask (MP has a selector menu for each in latest beta) but not if it was OK to run both. Thanks!!
At one point it wasnât safe as @rbachtell 's broken Solo will attest to
So reasonable question - but safe now!
Wow, enabling all this goodness sure is effective! This is on my 5" 210 with a Pixracer, Dynamic FFT (no ESC telemetry), Dynamic Harmonic and Double Notch. I suppose Double Notch isnât required on this little guy?
Pre:
Post:
Hah, yeah pretty dramatic eh? Do another tune and fly, fly, fly
I think on smaller quads the double-notch is counter productive - the peak is so pronounced that you want the attenuation that a single-notch can give rather than the breadth of a double-notch.
Roger that. I looked at the Load on the Pixracer and itâs ~53% max. No problem
When you tune:
- Set FLTT to 0 first
- Set AGGR to 0.2
After you tune:
- Set FLTT to 30 or so
- Do NOT set ATC_ACCEL values to 0
Hi Andy,
Could I get your thoughts on my pre and post harmonic notch results?
Pre:
Post:
As you can see, thereâs a dramatic difference! Is there anything else I should do to further reduce the peaks?
I am currently running throttle based as my ESCs donât support telemetry.
INS_HNTCH_ENABLE | 1 |
INS_HNTCH_FREQ | 60 |
INS_HNTCH_BW | 30 |
INS_HNTCH_ATT | 15 |
INS_HNTCH_HMNCS | 3 |
INS_HNTCH_REF | 0.44 |
INS_HNTCH_MODE | 1 |
Thanks!
Your primary harmonic is at 32Hz so you might do better to set INS_HNTCH_FREQ to that but use a narrow bandwidth - 15Hz say - to avoid control issues
You could also increase ATT to 40
You might want to set INS_LOG_BAT_OPT to 0 (not 1) and re-test for better averaging/oversampling.
Of course Iâm just parroting what Mr. Piper said a few days ago
Okay, thanks for your help Andy & Dave. Iâll give those suggestions a try
I have a PhD, so technically itâs âDr Piperâ âŚ
Excuse the error Dr. Piper, I should have know that!
Good morning Dr Piper and Sir Dave lol,im going to have an other go at my 3 incher bloody health gets in the way,is there much difference between using FFT or the Harmonic tuning please
Use ESC telemetry if youâve got it. Otherwise, FFT is better than throttle based notch.
Yes, what wicked said. I have transitioned thru all of them. I donât have a craft flying with ESC telemetry now so in lieu of that Iâm using Master on 2 craft (a 5" and a 13") with FFT and itâs working very well. Both of these are âOK to crashâ though, Master wonât be best for all certainly.
Thank you,Wicked and Dave will probably try and set up esc telemtry put need to get a new cable for my 4 in 1 esc
