We are in the process of tuning a large (1m/T-motor U10II KV100/29x9.5" prop/ Alpha 60A 12S) quadcopter with an AUW of 14 KGs. For initial tuning, to achieve stable hover we followed the Tuning Process Instructions. The thrust expo was set to 0.1 and INS_Gyro and Accel filters were set to18Hz. After getting a stable hover flight, Harmonic Notch was set and Autotune Autotune was performed in calm weather with little to no wind. The AGGR was set to 0.1 and autotune for each axes was done seperately. The following gains were obtained as a result:
ATC_ACCEL_P_MAX,56413.14
ATC_ACCEL_R_MAX,61027.36
ATC_ACCEL_Y_MAX,13308.42
ATC_ANG_PIT_P,6.331952
ATC_ANG_RLL_P,7.330026
ATC_ANG_YAW_P,5.698756
ATC_RAT_PIT_D,0.001093843
ATC_RAT_PIT_FLTD,10
ATC_RAT_PIT_FLTT,10
ATC_RAT_PIT_I,0.08437172
ATC_RAT_PIT_IMAX,0.4
ATC_RAT_PIT_P,0.08437172
ATC_RAT_RLL_D,0.002024285
ATC_RAT_RLL_FLTD,10
ATC_RAT_RLL_FLTT,10
ATC_RAT_RLL_I,0.1043671
ATC_RAT_RLL_P,0.1043671
ATC_RAT_YAW_FLTE,1
ATC_RAT_YAW_FLTT,9
ATC_RAT_YAW_I 0.1120059
ATC_RAT_YAW_P 1.120059
After AutoTune, ATC_THR MIX_MAX was set to 0.9 and flight was done. It felt a bit extra sensitive to RC input which was resolved by increasing input_tc to 0.25. However, in loiter mode during horizontal movement, the copter was acting very strangely. During horizontal movement, when stick command was given the copter would initially gain speed and then brake suddenly for a brief moment and then continue forward causing an oscillatory type of behavior. From a pilot perspective, it felt like, the copter was not able to maintain its speed or angle and braked when it exceeded the set limit.
The flight log is attached below:
https://drive.google.com/file/d/1KcYZ0wma5pwHF-5Lrl_Iqf5HN5dcFGb9/view?usp=sharing
Any help in this regard would be very much appreciated
Thank you.
