I need to know the CAM event on a finer resolution.
Is it possible to get this tag at a finer resolution? At what frequency does the navigation module or EKF is working at? Even if the GPS is updating at 1,5,10 Hz, navigation solution can happen faster and then the log can be maybe tens of msec (maybe faster?).
No, it is not possible without changing the source code.
Each message is logged at different frequencies, there is no such thing as a single global logging frequency.
Save the parameters so that you can downgrade later… and update to 4.0.4 to re-test. If it works worse, downgrade and re-load the parameters that you saved before.
Very fruitful discussion here for anyone interested. I was not able to get better logging resolution however. Seems using the TimeUS logged at usec resolution can be used to interpolate the CAM time better than the log.
