Thrust stand for Agriculture drone motors
I am curious to know that how could a thrust stand/bench test be constructed for Hobbywing combo motors which has ESC inbuilt, is there a way to measure rpm and current through any ESC, as in LY 30 kg trust stand I saw, there are two wires connected to the two terminal of motor is then connected to ESC, why is that, actually, I want a thrust that measures thrust, torque, current, power, and also RPM, any suggestions for this build, and one more requirement I want the data live on a GUI any option source options available ? for this type of applications
We use this one, works great, and meets the requirements you described
There are others described in How to methodically tune (almost) any multicopter using ArduCopter 4.4.x
By the way, one of the core developers, Matt Kear created an open source thrust stand.
Isn’t it the motor manufacturer already done that for the user? Do you mean it can’t be trusted or you plan to use it outside the recommended voltage or other condition?
Which hobbywing combo motor are you looking at?
No its not that case, it is needed for the validation purposes that if we modify the propellers how it would react and changes in thrust values so thats why it is required, i was looking for hobbywing x6 plus motors
X6 plus motor I understand now comes with a CAN interface variant. In our experience same pitch spins slower and provides the same thrust giving better power consumption. A higher pitch same diameter causes power consumption higher. A higher pitch same diameter with more blades may not yield better power consumption.
Maybe you will be interested to read these.
  1. Propeller equivalence – By Alex Evans - NMAA - RC Club
  2. Propulsion by Propellers
