Thanks Nathan,
But why is one perfect and the other one terrible while using the same settings and in the same conditions?
That is the answer I’m looking for here.
The EKF and environment. The computer did the exact same math, but with a different assumed “zero” from the accelerometers and gyroscopes from boot. The INS parameters are different because of a different physical state during boot. The difference is very slim, but it obviously had a bad effect because of the unstable PID’s.
Do increase a period. I need to read up on that type of controller - I may need it in my work soon - but from what I understand about it either a period or damping should be increased. Most likely period, my guess would be around 1.5x times.
I looked back on your other threads, and I think I might have given you some bad advice above here – looking at your STER data shows me that your desired and actual turn rates match very closely in both logs. Don’t change your P and FF values yet.
Seeing the desired lateral acceleration osciallate means that the navigation controller is the one that is causing oscillations now. Your L1 settings -
NAVL1_PERIOD
NAVL1_DAMPING
NAVL1_XTRACK_I
Probably need to be tested and optimized. Try increasing the period and decreasing the damping slightly. If I remember correctly, we had you increase your TURN_MAX_G from previous missions so that you could turn sharply on corners. Unfortunately that probably allowed the navigation controller more authority during straight runs - and now its settings are causing some oscillations.
That is really interesting, I will certainly try that.
Thank you once again for your efforts Nathan.
I think I need to go to a local dam and camp for a few days so I can test as soon as I get the info.
Where in the world are you from? I am in Durban South Africa
I don’t know if you can, but the single best thing that saves me time tuning is a good telemetry radio (RFD900 or something similar). That allows me to make parameter changes in the middle of a mission to see the outcomes. Most of the parameter changes here do not affect hardware, and they do not require a re-boot to see the effects. They are live, so you can try them as you go. It might save you a lot of time.
The rover isn’t “self-learning,” so it doesn’t surprise me that it can be unstable at times. Sometimes the smallest things can throw it off when it’s very close to being unstable.
It’s difficult for the same parameters to work on all vehicles. Some are tiny RC cars while others are houseboats. It’s crazy what ardupilot can control once the tuning is complete.
For what it’s worth, these are the parameters compared from log to log. All of the INS parameters are changed on boot, so that’s why they change. BRD_SAFETYOPTION and RC4_DZ were probably changed by you, but the rest change every boot.
Could it be that the code is not tilt compensating the compass? A slight roll in the boat will give a compass change of a few degrees which will cause the rudder to try to correct this imaginary course deviation introducing a wobble into an otherwise straight path.
Put the boat on land and introduce roll and see if your yaw changes.
If the craft is heading in the right direction, the only thing that could possibly change when there is no wind, current or chop, is the compass going nuts IMHO.
Do you have the compass readings at that time?
What happens to the compass if you roll the boat on the bench?
If the software allow you change the smoothing of the compass readings, You probably only need to act on compass changes once per second so smoothing over 10 or 20 readings (assuming read rate is once per 100ms) should still give you enough info to not oversteer on gentle turns.
Not sure if ardu pilot uses the gyro and compass for yaw control, if so, adjusting PID only on the yaw control might not be enough but would help.
