I am quite new to this kind of integration, i tried understanding from the various topics that have been posted by @ppoirier and other people but still cannot manage to get my TF MINI S to work with my set up. (image below)
What i am looking for is some sort of extensive and detailed manual or description and some guidance on how to set up 5 TF MINI S to be used as obstacle avoidance system on a quadcopter. the orientation of the TF MINI S will be:
forward
backward
right side
left side
downward
All your inputs are very much appreciated.
EDIT: I am using the last version of MP to set up the parameters and stuff.
Good day, if you need setup TF mini-S like a tower, you need set for every sensor a different i2c address and wire it on an Arduino board.
Me I’ve choose CAN protocol for the TF mini S… im still working on it
Could you advise some circuit diagram/schematics and code/library to use on arduino.
Since i am quite new to this kind of integration, the more information i get the more helpful it will be to achieve this.
