Depend on company (marketing or provide value for money)
Because there is no more under budget radio to provide feel better (middel class thinking)
Happy flying
Happy flying
Thereâs two different versions of the Taranis. The Horus donât even come close to a Taranis-E, which is what I use.
For me the Horus is a non-starter
I have the 10S. I love it. I came from the Futaba ecosystem.
I do run open TX on it, and once you get used to it itâs fantastic
Dave so you prefer 10S over Standard X9D+ as a better option? What are the key difference you like and why?
One of my friend claimed last month that his Taranis X9D+ Got infected by a virus and he had flush his radio??! Never heard that before or is he smoking better stuffâŚ
As far as Futaba goes, I know its a different category of systems. You pay top dollars for reliability and high standards of manufacturing. To me its like iphone vs. Andriod phone battle. high end receiver is like $200 dollars and paying extra for Brand name as well.
The 10s was my first step outside Futaba. I came from a 14sz radio.
There is something to be said about the really nice color LCD screen on the 10s
Yes agree, i think step up from X9D is probably 10S at this point. Then you got ACCESS to consider but then what to do with old RX
When I have time I will put a spreadsheet together to compare the feature functionality, reliability, ease of use etc. we can all update it together and we will have a point of reference.
I put one together for LiDARs on DIYDrone site once. It became pretty popular and helpful for people.
Thatâs actually a pretty simple comparison.
Difference case styling
Color TN screen vs LCD
M10 gimbals vs M9
Higher power consumption in the Horus.
Thatâs about it. Oh, I guess the Horus has one more pot. But if you need more switches and/or knobs the X9E supports up to 20 of 'em (and has the internal board for it).
Otherwise there is just no real significant difference in performance or features of the two and they both run the same operating system.
LOL! Now thatâs a good one! Did he put the radio in quarantine too?
ChrisOlson lol I know. So when he told me that, I sent him the following pic. Please always use K95 masks with your Taranis, N95âs are for US only
There is also one other significant difference, and that is with Lua scripting. Scripts written for the Taranis are not compatible with the Horus, as the Horus uses âwidgetsâ for its TN display. While Lua scripting for the Taranis is very well documented, it is not for the Horus.
If you use a âpackagedâ script like yaapu, then no problem. If you write your own like I do it is more difficult on the Horus. I have a custom script for helicopters that has dual-needle tachometer for rotor/engine rpm, gauges for engine temp, generator, SOG and KIAS etc⌠Various people have tried (unsuccessfully) to port it to the Horus.
ChrisOlson This is a very good point!. Custom scripting brings a lot more flexibility to the table.
By the way, how good are you with Lua scripting? I may have a small gig for you. let me know and we can talk off line.
I can program with Lua just fine. Itâs not all that different from C++ but some things are different like functions() have to be declared ahead of a call, variables are declared on-the-fly, and so on. But unfortunately I donât have time to do custom programming for other people.
@smartdave @Moksh @dkemxr @davidbitton @ChrisOlson @UnknownPilot
SmartDave convinced me and I have ordered the Horus X10S. I am hoping that I will like it. As I am a hardcore Futaba guy and I have only 3 Taranis X9D compatible Rx so far, may not be be bad idea to switch to Access. If I really like it, then I will sell my X9D
Now the questions coming to mind are;
R9D would not work with X10SâŚWhat is my alternative for long range?
X10S receiver choices are little confusing so far to me;
a) Archer
b) Rx Series
Still trying to understand the differences. Not sure if these Rx has an S Port and whatâs the advantage of FPort?
Will my Yaapu cable will still work?
So many questionsâŚ
You can Brose it FrSky FPort support - testers wanted
This is for information purposes
Also fport = only 1 wire to need rc in also telemetry data and are you using fport protocol you i will be donât need yaapu cable and there is lots of advantages showing on video.
Happy flying
a)Archer is the ACCESS version of the XM+ w/ telemetry. Low cost, lower range. Havenât tried them, likely popular with the mini-quad/racing crowd.
b) Do you mean R9 series? If so comments above.
Fport is single wire RC and telemetry with less latency. This may be quite helpful when bi-directional Frsky telemetry is available.
Regarding ACCESS, if you are starting with Frsky its the way to go. I have older Frsky hardware that is not compatible so Iâm out of luck unless I want to replace a slew of Rxâs on models, buy a new Tx and buy a new R9 module.
Thanks⌠Is it safe to assume the R9 series long range plug in module will work with X10S? $24.00 dollars on AliExpress to me is a no brainer not to buy it
@Moksh ok I got it what it means one wire. Both sPort and FPort over same wireâŚboth protocols are mixed so donât need to run two wires from RX to FC.
Furthermore, so all my current FrSky Rx such as X8R will work with X10S. Thats good. This means I only need to sell my X9D plus and keep the rest of the hardware including Individual LiPo cell voltage monitors (the main reason i started using FrSky because Futaba can only do total voltage monitoring via its Rx, no individual cell monitoring supported). I have not seen one out there.
Yes, The R9M is a JR module form factor. Make sure you are buying the 2019 version or you wonât have ACCESS. There is a External Power input difference also. After posting that I had no problem using a 3S Lipo for external power I had to eat some crow when that module failedâŚ
Both Telemetry and RC Control over one port. Otherwise itâs Sbus and Sport (telemetry)on 2 separate ports. One many boards this takes 2 UARTS.
Dave what do you mean by external power? Wouldnât X10S power the 2019 R9M? Kind of lost you thereâŚ
P.s. One Uart saving is huge. Mr. Yaapu is a plain Genius. I love how his brain functions. Smart cookie for sureâŚ
The R9 module pulls more power than the radio can safely provide. There is a xt30 connector on the back of the module
