I already tried setting the Camera gimbal setting on MP but the trigger wont work when i switch CH7: I connected the PWM on the AUX pin on pixhawk on AUX2 (SERVO10):
What am i missing? The manual trigger wont work when i tested it, I cant go on to triggering on autopilot if i cant make it work on manual trigger using CH7:
You have the trigger duration set to 100msec, perhaps its too short? I tested this setup in SITL and Ch10 output toggles from a DO_DIGICAM_CONTROL command so its working.
No. That is a Auto Mission command to trigger the camera. I was just saying that with the settings you have it switches the output on Chan10. As a test set the duration to 5 seconds (50 for the parameter) and then look at the Ch10out on the Status Screen while flipping the assigned switch. Does it change from 1100 to 2000 for 5 seconds? It does on my bench test setup showing that functionally the Arducopter configuration and the Pixhawk is working. If you find the same then the problem is with your camera.
Okay sir, i will test this tomorrow and give an update. I will check on the status if the CH7 move from 1000 to 2000. Once i tested the camera trigger manually, i will move forward to Auto Mission using the QGroundControl app.
Also, what are the necessary parameters that needs to be set for camera trigger on manual? And on auto with QGround? Aside from the camera gimbal page? Thank you.
Does ch10out switch to 2000 for 5 sec when chan 7 does? It will only toggle for the duration set that’s why I suggested setting it to 50 (5 sec) to test it so you have time to watch the change.
Just answer the question about ch10out. is it working or not?
I dion’t know anything about that camera I’m simply trying to help you determine if the configuration is working. If it is then you figure out why the camera doesn’t trigger.
Then it’s configured correctly. I don’t know what you are showing with the photo of the FC and the connection to Aux 10. Connect the gnd lead to the top pin and the white PWM lead to the bottom pin of Aux 10.
