there is 1 more bug in MAV_CMD_DO_GIMBAL_MANAGER_PITCHYAW function implementation.
Flags (0=Yaw is body-frame/follow, 16=Yaw is earth-frame/lock) - this FLAG is not correctly handled. Actually it is treated as Yaw angle.
Thanks again for the report. I had a look through the code and I don’t immediately see any errors but of course that doesn’t mean that there aren’t any.
I guess you are testing sending mavlink messages to AP using a custom application or maybe MAVProxy? I would like to rule out a ground station issue so I wonder if you could test using MAVProxy and ideally use the example commands that can be copy-pasted directly into MAVProxy’s terminal window.
So to be clear, setting the flags to 0 or 16 will affect how the yaw angle (param2) will be interpreted. If flags is 0 then the yaw angle will be interpreted as a body-frame angle (e.g. 0=point forward), if flags is 16 then yaw angle will be interpreted as an earth-frame angle (e.g. 0 = North).
Maybe this is where the confusion is coming in?
If not, could you please describe what yaw issue you are seeing? Perhaps provide an onboard log…
