Sending Unknown Message (44) on Mission Planner with Speedybee F405 v3 Guided Mode
Hello! I’m creating a new topic on this (my previous problem is solved, and now I can fly in guided mode).
I already tested my codes on SITL using MP, when I used it on my quad, well it works somehow (just need to tweak the WP_RADIUS), but my problem was when I started to run my program (listen, arm, takeoff, waypoint, RTL), I see this messages on Mission Planner. It spams Sending unknown message (44) every second.
I’m uploading my test codes in python. Can someone help? Thank you.
droneActions.txt (13.6 KB)
mainRun.txt (452 Bytes)
Hi, mine says 45 :grin:
I have no idea what this could be, but I have compiled 4.6.0beta3 Plane with many custom options for MatekF405-Wing-bdshot.
This is empty board just after uploading firmware
Hi @Arvee_Domingo, @kolin,
thanks for the report. This is on the 4.6 issues list and I’m sure we will resolve it for -beta5. The issue is innocuous but annoying so thanks again.
I’ve also moved this discussion to the 4.6 category
This is GCS_Common: fix missing #if for CAMERA_FOV_STATUS by robertlong13 · Pull Request #29339 · ArduPilot/ardupilot · GitHub
Mission Planner has also been fixed
I have saw 44 error on 4.5.6 OSD
