SDP33 AirSpeed Sensor Preflight Calibration (MS4525DO vs SDP33)
Hello!
I Tried doing a preflight calibration on a fixed wing. Everything seems to be working fine, but the SDP33 sensor calibration does not throw a “Complete” message. Is this normal?
I have tested the sensor in flight and it seems to work fine.
Thanks!!!
Here are my setting for SPD33. Also, you don’t need to do a pre-flight cal on these, its already calibrated. Mine works great.
|ARSPD_TYPE|6|
|ARSPD_USE|1|
|ARSPD_OFFSET|0|
|ARSPD_RATIO|2|
|ARSPD_PIN|15|
|ARSPD_AUTOCAL|0|
|ARSPD_TUBE_ORDER|2|
|ARSPD_SKIP_CAL|1|
|ARSPD_PSI_RANGE|1|
|ARSPD_BUS|0|
|ARSPD_PRIMARY|0|
|ARSPD_OPTIONS|0|
Also, here is an entire post on that sensor:
