I haver pixhawk cotroller, Turnigy 9X modified radio with FrSky XJT module. When I use FrSky D8R transmitter the telemetry is going well.
Can anybody describe me how can I use (and connect) FrSky X8R transmitter smar port to pixhawk? I am electrician the best solution will be a small cheap circuit. I tried this:
If you got the D8R running already, it’s the SPC Cable that is missing, that’s the one I got, but you seem to be familiar with the electrical circuit so you can easily build one on your own
Please note, you need Craft & Theory’s custom firmware located on their site.
And, you might want to follow us on Ersky9x forums.
I have the same setup and we are working through it now activating the individual telemetry readings: http://openrcforums.com/forum/viewtopic.php?f=95&t=9164
The TTL-to-RS232 convertor I bought was a dual convertor type. It means that the pads on the bottom are convertor one, and the solder pads on the top are for the second one.
I ruined the pads on one side, so I could luckily use the other one side.
Perhaps you have the same type of convertor and accidentally connected both sides?
Otherwise I don’t know. Perhaps a faulty convertor? Try another one?
Great hint… Thanks
I soldered the wire to the receiver under the board, as I didn’t know that it is a dual converter.
So there was a loop from T2IN to T2OUT over the Diode to R2IN and fried the chip.
Remember:
Do not connect to Pixhawk withot connected the receiver, as it will fry the MAX3232
