Actually I am using the Spektrum DX7 as a transmitter with an original Satelite Receiver (SPM9646). The receiver is connected directly to my Pixhawk 1. This runs perfectly.
Now I want to use the Telemetry Functions on the Spektrum DX7 with the Remote Serial Receiver with Telemetry (SPM4651T). In the AduCopter Documentation I found that the SRXL2 Protocol is compatible.
But my question is if the Telemtrie function is also supported by the pixhawk? Does anybody has experience?
Since you are the only person I know of apart from me with an SRXL2 device I’d be happy to do you a firmware build with the support to test if you want.
That sounds very nice!
But before, my question is where I can connect the Receiver? Today my SPM4651T has arrived.
It is not possible to use the the DSM connector on the pixhawk?
And how can I make a firmware build with your PR? Or do you share a firmware with me? What does PR stand for?
Sorry for my questions, but I have no knowledge of the subject.
I can build you the firmware if you tell me what board you have. Note that the firmware build would be against master (the current development branch in github) with the usual possibility of bugs and issues, so if this is for a machine that is especially valuable or you don’t like risk then I would wait until this makes it into a released version (probably several months from now).
What receiver do you have? If it’s one that operates in remote mode then you can just pull the latest master firmware from https://firmware.ardupilot.org/Copter/latest/ as SRXL2 is already in master. It’s only this weird bootstrap version that is not.
