We are using 5 serial devices on the Cube:
- GPS
- Emlid reach PPK
- Telemetry
- Lidar
- Ping ADS-B receiver
But only 4 serial ports are available.
How to solve this problem?
In other words, where are serial 5 and 6?
There are 5 right? Using the CONS (UART 5) port?
Ah, OK. That should be serial 5. Do you know where to find serial 6?
I know of only 5 serial ports.
I believe the functionality of using an Aux pin as a serial port is coming (for serial 6, etc.).
Thanks a lot. For the time being I need 5, so I have my solution. I didn’t realise that this cons pin was serial 5.
Thanks for the info. That would be great for future devices.
Thanks for the info, but I don’t consider that an option. Too much extra hardware which makes the system less reliable. Right now I have the 5 I needed, and if no 6 comes available on one of the aux pins, I’ll be totally happy. But thanks for pointing me in that direction.
1 simple teensy board with a mavlink forwarder code, adds 3 hw serial plus you can use softserial. So you can use devices that use Mavlink for serial comms on a single Cube port.
@Eosbandi Have you done this or is it theory? Do you have code for this? I’m not super familiar with teensy, I only know of it.
Done in a bigger project. Will try to extract relevant code and publish it.
Yes , CANBUS & MAVLINK are adding components and if you want to keep it minimal you could use an I2C Lidar ?
Reviving this to ask if Serial 6 is alive on the cube with chibios (3.9.x), and what port/pins that translates to?
I see it listed as a param in my SITL running 3.9.7, haven’t loaded to a physical board yet.
Cool! now does this functionaly apply to the pixhawk cube and where do I plug something in to be on serial 6?
