Version 0.9.0 of Rpanion-server has been released!
Rpanion-Server is an Open-Source software package for a managing the companion computer (such as the Raspberry Pi) connected to an ArduPilot-based flight controller.
Rpanion-Server consists of a node.js-based webserver for the user interface and mavlink-router for routing MAVLink telemetry from a connected flight controller. There are also modules for managing network connections, NTRIP streaming, flight log management, video streaming and viewing hardware information.
Version 0.9.0 adds the following major new features:
Automated uploading of flight logs
VPN support (Zerotier and Wireguard)
Automated generation of KMZ files from flight logs (thanks @brunoolivieri!)
Timestamp overlay for video streams
Various bugfixes and ease-of-use changes to the GUI
The documentation and pre-built disk images for the Raspberry Pi are available here .
@stephendade This works on a Raspberry Pi Zero W right?
I have some of these lying around and I wanted to install them on my most frequently flown planes so that they can upload logs to a cloud location. This can be done when on my mobile hotspot after landing or when just powered by USB when they come back home.
I have skimmed through Randy’s blog and I have some familiarity with AWS.
Is the cloud upload of logs automatic or can it be? Obviously these logs would be the same as telemetry logs if I had a GCS or are they more more verbose than that? Edit - I notice Randy refers to Dataflash logs. I am confused – I did not think these could be sent via Mavlink.
Yes, but you’ll need to build it yourself. The pre-compiled image doesn’t work for the Pi Zero W (1).
If you can, use the Zero W (2) instead. Rpanion-server can be a little tight performance-wise on the Pi Zero W (1) if you’re running a bunch of features at once.
I can build myself but I basically refuse to buy a Pi 2 Zero W for $150. It is not about money as much as principal. It is a vain and self-defeating principal, but I am not giving money to such folks that buy them and immediately flip them.
The only thing I will be using it for is Dataflash logs. Is that a reasonable expectation that it could manage that?
I forgot it has been years since dataflash logs were transmitted by Mavlink – thanks for the re-explanation.
