Hey folks,
Apologies for another newbie lawnmower thread. I want to first say that I try to be very conscious of everyone’s time and have spent a fair amount of my own trying to understand before bothering everyone. I’ve reviewed Yuri & Kenny’s videos, browsed the forum a little, reviewed the ArduPilot tutorials, etc. I am hoping you will permit me a few elementary questions to help me better understand the bottom line capabilities so I can make sure I have reasonable expectations.
I have an airstrip and some open fields that I currently mow; adds up to about 15 acres of ground that is open with only a few obstacles to consider (runway lights mostly). I currently use an old International tractor and a batwing mower to mow it about once a week, and while that is considerably faster than the 60” zero turn I was using previously, I do find myself spending a lot of time mowing. My wife and I have 3 young kids so I’m hoping an automated mower will help me shift how I spend some of my non-working hours.
I spent some time working in the unmanned aviation field and took a lot of that for granted instead of learning the real mechanics of it all. We had an autopilot module and RTK module on the aircraft, and a ground station with directional antenna (to update waypoints real-time, send payload commands, etc). It was all very seamless as it was a fairly established system at the time, but I never thought about how it all works.
First question; This station is about 14 miles from me:
https://www.pagis.org/index.php/data-resources/reference-station/. I don’t truly understand what sort of information I’m going to need to be able to receive for reference, but this station has a Trimble Alloy GNSS Receiver and it says they’ll provide no-fee RTK. I would assume this would get me going with a high level of accuracy, right?
Second question; getting this all to interface with the mower controls is the part that I’m having the most trouble understanding (the autopilot outputs, giving the autopilot information, controlling servos, etc). I’ve read about disconnecting the gas-shock dampeners on the zero turns and using servos to move the control levers at or near each individual wheel pump. What about on a mower with a traditional steering wheel? Trimble makes a product called EZ-Steer that is basically just a motor with a thick foam/rubber wheel on the shaft that rests against your steering wheel and provides the steering (see pics for context). Has anyone tried anything like that, or is the zero turn method the least difficult? I have a nearly new zero turn I don’t mind using for this project, but I was curious if a different style might be more appropriate. I don’t usually make any pivots turns when I mow it now. I just make loops around the entire thing, starting in the middle (the middle is paved) and then mowing in ovals that increase in size with each path. I wasn’t sure how well these handle shallow arcs, or if they have to be pivot turns because of the waypoint to waypoint nature of this.
I don’t want to be a burden that has to be dragged to the finish line on this, I just need a little help with the big picture thinking on the front end.
Thank you all in advance!
