I tried this on my sailboat last year. I scaled the steering back to zero at zero forward speed at speeds lower than about 2m/s I think. I found that the gps speed was not so accurate at slow speeds so it wasn’t that good. The other issue is if your more or less stopped oscillating between going forwards and backwards you end up with the steering oscillating from full left to full right.
I tried 4.0.0.rc1 it with my Tractor.
Somehow “DO_CHANGE_SPEED” in auto mission had no effect.
I’m quite sure it was working with 3.5.1.
Nice, is there firmware for the Matek 765-wing for beta 4.0?
Thanx! Trying to get it on the board tonight
We did hook up the Ping Sonar sensor and it seems to show up in the Mission Planner screen when tested in our water tank. On the other hand I am unable to find the range information in the APM log: https://we.tl/t-NRThhOxdxI might be my mistake?!?!
@vbnhu, I had a quick look at the logs are they are very short. I’m not sure the vehicle is even armed. Perhaps try arming it and leaving it for a minute and then check if the DPTH and RNGF messages appear.
How do we do compass calibration on the water?
I would really like to add obstacle avoidance for those large buoys and moored boats, but I fear LIDAR and water are not a good match.
Re compass offset learning, I’ve never tried it on a real vehicle but I have tested it in the simulator and this is the procedure:
- set COMPASS_LEARN = 3
- the message “CompassLearn: Initialised” will appear on the MP’s message tab (it does not appear in red letters on the HUD).
- “Bad Compass” will appear but this is nothing to be worried about. We will hopefully make this disappear before the final release
- Arm and drive the vehicle around in whatever mode you like, do some turns
- “CompassLearn: have earth field” should appear on MP’s message tab and then eventually “CompassLearn: finished”.
- if you want you can check the COMPASS_LEARN parameter has been set back to zero (you may need to refresh parameters to see this) and the COMPASS_OFS_X/Y/Z values will have changed.
Note that this is a simple calibration of offsets only. The 3D compass calibration does a better job because it calculations scaling as well. But for cases where it’s not possible to lift and rotate the vehicle hopefully this new method will be better than nothing.
Great thank you Randy, I will certainly give it a try.
@rmackay9 Could be possible to have a LOIT_TYPE 2 option to force a boat always reach the loit target with the back, as opposite of LOIT_0? that would help to prevent the fishing line to go in the prop while fishing on a boat in loit mode.
Yes, it’s possible although I can’t immediately promise when I will personally get to this. It’s possible that one of the other developers may though and the change itself is not that difficult. I’ve created an issue here.
No hurry, thanks for the great work!
Good work! LOIT_SPEED_GAIN is very needfull param. Before this release, when loit radius was 1m boat always overshoot the radius and constantly sailed from side to side. Presently everything is fine, and boat moves very smoothly.
These are rover trajectories on a mission of a rover (with 4.0.0-rc1 and RTK GPS) followed by three drones (for more information see this):
that can be compared (same speed (3m/s)) with 3.6.11:
Much better now.
BTW1, after flashing WPNAV_SPEED was 4m/s. I’m sure it was 3m/s before flashing (4m/s made rover knock circuit barrier at the second curve after the long straight). I didn’t notice it, and in the first test with 4.0.0-rc1 the car hit that barrier. I’ll try 3.5m/s (and next firmware) shortly.
BTW2, this was GPS status:
@RainFly I have encountered the same problem with DO_CHANGE_SPEED and raised an issue here: https://github.com/ArduPilot/ardupilot/issues/12753
