Reading Logs for Battery Failsafe Testing
Hi experts needting your assistance on this please, I tried the battery failsafe to test that if the drone will shift to RTL once the battery threshold level is reach. I dont know whats wrong with my drone, it doesnt Return to Launch :frowning:
These are 2 logs:
https://drive.google.com/open?id=1fvBLLd2Q3M_dzUuXszS0aOBbh8N2NrKf
Both of those logs show RTL by battery failsafe.
Yes it is, my problem is, its not returning to where it should RTL on take off. Is the GPS damage? It didnt give exact location. On failsafe
it because of that your GPS HDOP is higher than 1 at most of the time you have to wait more to get more satellites
you should have at the least 12 satellite count for a mission fight
note that lower HDOP is meaning your GPS is more accurate
also check out this part of wiki
depend on your location you can set witch satellites your copter could use
http://ardupilot.org/plane/docs/parameters.html#gps-gnss-mode-gnss-system-configuration
Your expectations are too high. It will rarely land in the exact spot even with good reception with standard M8N modules.And next time you report a problem like this give a more detailed explanation. “It doesn’t return to Launch” is ambiguous.
Hi @dkemxr thanks for your response, yes im not expecting it to land on exact location. My concern is that, when changing to RTL it lands on a bit far from the location where it takes off at least 6-10 meters. I guess is supposedly should land at least near on the location where it takes off.
So what do you suggest ill do? Change to what kind of gps?
Thanks @hosein_gh, ill check the hdop next time i fly. And the number of satellites.
Banjing,
6-10 meters is too much. Max should be under 2 meters if you start with a good fix on the m8n.
The m8p & f9p will do much better when running RTK in float or fixed mode. However looking at your log, your m8n GPS is not performing as well as mine.
I suspect your GPS mount and RF interference is degrading your results.
Please post a photo of your Copter & GPS.
HACC & VACC should be well under a meter.
Hi @mtnsurveyor this is my drone, the GPS is located above the fence, created to protect the Pixhawk.
https://drive.google.com/open?id=1bDWmOU79jRBmFPryEqNDitDHEW5RCJ1x
This is what I thought.
Place the GS radio below the copter, Orient the GS antenna downward 15deg off vertical.
Raise the GPS a inch or 2. Guarantee you get better results.
Yes Curt is right. Another good place for the telemetry radio on those frames is off the lower plate in the back. In fact you could locate several things on the lower plate. The only thing I had on the top plate of an F450 frame was the FC and the GPS module.I would get rid of the cage too it’s not helping any. For sure it will add some offset to the compass.
Thanks @mtnsurveyor i will try on rearranging the GS and raise the GPS for about 2inches, and try to remove the cage. Will it work?
Hi @dkemxr thanks for the inputs, i will do as you guys said and update for the result.
Anywya, aside from cage what can you suggest that i used to protect the FC i mean cover.
Hi Experts, needing your assistance please, I tried Loiter to RTL today as you suggested to remove the cage and adjust upper the GPS but it seems im having still a problem:
Please see this log:
Please describe problem
Please help me read the logs above. The problem is, it says Warning: EFK2 IMU1 ground Mag Anomaly Yawre- alignment on QGrounControl But this drone already done AutoTuning Yaw, Pitch and Roll. The only changes I made is i removed the Cage, put the Telemetry below copter and Used a stand for the GPS.
And Still, didnt return at the nearest home when RTL. Also, Upon opening the Misison Maker App, the “H” is far away where the Drone is supposedly located. Satellites is 12.
ignore this message its not about autotune its just a in fight realignment
did you tried this :
your GPS accuracy still is to high (minimum 2.1m)
location of all your parts now is fine
just i think something is coupling vibration to your fight controller because your z vibration is increased too much from last (its not the reason of GPS accuracy just an advice for a better fight)
Right, ignore that EKF message. Did you re-calibrate the compass’s after re-mounting the module and removing the cage? It’s required. Yaw actual vs yaw desired shows some yaw instability.
No idea about Mission Maker, is that even supported any longer? I use QGC on Android and IOS.
