Having recently built and flown several different kinds of Quadplanes, I thought that I would add a hints and tips page to the wiki due to some unique facets of Quadplane that are not covered currently… here is the first draft and I welcome comments and suggestions for additions for us to consider before I PR to the wiki…its in .rst format as would be added to the wiki so some of the formatting will, no doubt, be messed up(the table is really messed up here,but format is perfect in the wiki):
… _quadplane-tips:
QuadPlane Tips
A few helpful hints and tips for first time QuadPlane users.
Motor Alignment
Motor alignment is always critical for any Plane’s performance, but it is especially so for QuadPlanes.
Miss-aligned VTOL motors can greatly affect basic VTOL performance, especially yaw trim and effectiveness, as well as fixed wing flight performance.
Checking motor alignment on the bench can be done by blocking the vehicle in a level position and measuring prop to table distances for all motors with props in fore-aft and side-to side positions. Measurement differences easily reveal miss-alignments. The arc-sine of the prop tip end differences divided by the prop diameter will give the tilt angles. A degree or two miss-alignment,while not disastrous for pitch or roll, can be significant in non-vectored yaw configurations with regards to extreme yaw miss-trim.
Miss-alignment can be also seen in the dataflash log RCOUT values in a hover for the VTOL motors. Yaw problems appear as large separation between diagonal motor pairs.
For vectored thrust frames, fixed wing mode alignment is also critical. Differences between motor thrust angles in forward flight will generate undesirable roll and/or pitch trim tendencies. Careful bench checking and adjustment of forward fixed-wing mode positions with respect to airframe and one another is required.
X vs H Quad Mixing
In theory, it doesnt matter which is used. With perfectly rigid mounting, no performance or flight difference will be noted as far as motor control dynamics. However, the actual implementation of the mounting can result in differences in drag and efficiency.
- X frame mounting or horizontal H frame type mounting creates the most drag.
- H frame mounting fore-aft (ie on the wings in line with wing chord) is the least drag, but also can result in a lot of flexing, depending on wing construction
In addition, if the mount method allows ANY twist to occur, serious performance impacts can occur. For example, a conventional style plane airframe has the motors mounted on cross members in the nose and rear fuselage. If the fuselage allows a minor twist to occur (like during yaw with one diagonal supporting most of the plane’s weight), which most foam style planes will, then if X mixing is used, the twist induced during yaw actually acts to decrease the yaw. In some cases, it can completely disable yaw effectiveness. However, the same configuration using H mixing, the twist will actually aid the desired yaw.
In general, in a Quad configuration , use H mixing and not X mixing.
AHRS “LEVEL” Trim
When you setup a Plane, the “level” calibration should be done with the plane in its normal cruising attitude (ie angle of attack of the wings). If the vertical position of the VTOL motors is not 90 degrees to this attitude, then the QuadPlane will tend to move forward or backward when hovering, requiring stick input to modify pitch.
Fortunately, there is a parameter which allows the independent adjustment of the VTOL AHRS “level” attitude. This is :ref:Q_TRIM_PITCH<Q_TRIM_PITCH> .
However, there is a better way. If mechanically possible, trim each motor to be vertical when the QuadPlane is in fixed wing “level” mode, so that using :ref:Q_TRIM_PITCH<Q_TRIM_PITCH> is not required. Usually this requires 3-6 degrees of forward tilt. This has the advantage of having the wings generate lift while hovering in the wind, reducing the load on the VTOL motors and preventing sudden pitch changes during transitions back to VTOL mode from fixed wing flight.
Battery Sag
Many QuadPlanes are targeted for duration and therefore may utilize high capacity to weight ratio, but low “C” , batteries. Battery sag in the initial phase of VTOL to fixed-wing transitions can be a real issue. Be sure to read the warning in :ref:quadplane-flying .
QuadPlane Configuration Pros and Cons
ArduPilot provides many different QuadPlane configuration options. Your specific application requirements will determine which to select.
However, the table below gives some general pros and cons of each configuration type. There is wide variations, but these are high-level generalizations.
+Configuration Type + Pros + Cons +
+QuadPlane +easier assembly + wing-mount: twist +
+ + fuselage-mount: drag + -
+ lower efficiency + +
+Tilt Motor Tricopter + efficient + complex mechanically +
+Dual Motor Tailsitter + easier assembly + poor stability upright +
+ most efficient + requires large flying surfaces +
+Belly Landing Dual Tailsitter + stable at rest + complex mechanically +
+ very efficient + requires large flying surfaces +
+Copter Tailsiter +very controllable + lower efficiency +
+ and aerobatic + + -
+ easier assembly + +
