Hello everyone, recently i buy one Pixhawk and here 3+ rtk kit, however the gps rover module came with the connector of the cube pilot, and i search for the pin configuration setup and i change the connectors however the pixhwak can’t recognize the gps.
I have no idea how you arrived at that pinout, but the Here 3+ is a CAN device and must be connected to the CAN port via the instructions from CubePilot.
Hello yuri Yes, the cubepilot have 2 connectors of 4 pins and the pixhwak have 1 of 6 pins and 1 of 4 pins for gps and i2c port and i use this manual instructions for find the order of the pins. And exchange the connectors.
Just to make things as clear as possible, the GPS port is simply SERIAL3 laid out to make connecting some common GPS/compass modules very simple. The Here 3+ is not a serial/I2C device and is not compatible with that port on the Pixhawk.
