I am using a Matek H743 wing and the Plane 4.0.6 Stable firmware.
The Plane is a towplane.
Therefore I need a way to fly a waypointmission in auto mode which achives 100% thrust all the time and a constant speed. (The climbrate is therefore is variable depending on the glider behind, thermals etc.)
Currently I have not setup a aspd sensor. I will use one in the future, but I would prefer to make it work based on gspd and windestimation as I want to use a redundant system, which will omit the (analog) aspd if it gets unplausible (eg. pitot tube gets dirt on it infliegt etc.)
So question 1: Is there a way to configure Ardupliot 4.0.6 to fly with the pich controlling the speed (TECS_SPDWEIGHT 2 and TECS_SYNAIRSPEED = 1 with no aspd sensor installed alone does not seem to work)
I have already found this topic which should fix my problem (basically I need glider logic -only maintain speed, forget everything else for vnav-) but i can not seem to get it working. Is the described principle implemented in 4.0.6?
Question 2: As soon as I have the aspd sensor installed, is there a way to configure ardupilot to use gspd or gspd with windestimate instead of aspd, if aspd reads unreliably?
Thanks
